Old 06-04-2015, 06:27 PM   #1
Left Coast
See any problem?
2010 Rockwood Ultra-Light, 8280 Model, 5'er........Came as...4000 lb. axles, ST 225-75r -15c rated tires ( no longer on...now g's ) with a GVWR of 9077. Empty or loaded rating?
Old 06-04-2015, 06:33 PM   #2
BamaBob's Avatar
Bob,
Gross Vehicle Weight Rating (GVWR) is the maximum number that the GVW or GTW should never exceed. GVWR is applied to trailers as well as vehicles, but you may see this rating referred to as the Maximum Loaded Trailer Weight.
Am I missing something?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 06-04-2015, 06:43 PM   #3
Left Coast
Originally Posted by HSVBamaBob View Post
Bob,
So, the 9077 should be the loaded number?...... If the axles are 8000 total, then that leaves 1077 for what-ever?
Old 06-04-2015, 10:15 PM   #4
1077# would be on the king pin
Jeff in NC is offline   Reply With Quote
Old 06-04-2015, 10:20 PM   #5
Left Coast
Thanks, good or bad? Tv doesn't squat much, but then it's a Dodge.
Old 06-04-2015, 10:55 PM   #6
asquared's Avatar
This would be correct. Go to the scales and see for sure. Get 1 pass of tv no fiver. Weigh front axle on scale pad one and rear axle on scale pad two. Then weigh with tv and 5er. Do the truck same as first pass and trailer axles on third pass. You can figure your numbers from there.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-04-2015, 11:17 PM   #7
Left Coast
Going racing ,leaving tomorrow, and there's a seldom used DOT scale on the way, so why not.
Old 06-04-2015, 11:27 PM   #8
asquared's Avatar
As long as your state allows it.... some do, some don't. We usually use a cat scale at a local truck stop. (This is easy for us as we have 4 truck stops and a blue beacon truck wash within a 10 min radius of the house.
2014 Sabre 34REQS-6
Old 06-04-2015, 11:34 PM   #9
Left Coast
I've stopped there before but never separated from trailer..It's mostly used during harvesting season, so shouldn't be a problem.
Old 06-05-2015, 12:02 AM   #10
wmtire's Avatar
Are you stating you now have Load Range G (14 ply rated) tires with a 15 inch wheel diameter?
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
