02-24-2016, 03:58 PM
Setting Tow Settings in DIC
My Ford F350 in the DIC "Driver Information Center" if you scroll down to "Settings" then to "Driver Assist" there two settings for towing. The first one sets up "Trailer Braking" has three settings Light - Medium - High that affects trailer brakes and should be set to what you are towing. Mine was set to light and wouldn't lockup the trailer tires till I moved highest setting. Second one is "Trailer Sway Control" mine defaulted to off and set this the way you want it. Some people like on and other off so what floats your boat.
I'm not sure if all trucks have those settings but if does they need to be set.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
02-24-2016, 07:08 PM
I never knew those settings existed. I just checked mine and it was set on light. I bumped it up to medium to see what happens next time I tow.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
02-24-2016, 07:29 PM
I think a lot of people don't know they exist, not even the dealer I bought my truck from. Did you check trailer sway was on of off? Mine was off but mine sat on the lot and who knows what settings were changed. If you bumped it be sure to check your trailer brakes on the next outing.
02-24-2016, 07:54 PM
Hey CW. Based on all the responses on the other thread, there are a lot of guys that aren't aware of these settings. I was one of them. Your description is accurate.
Thanks for the info. You've probably helped several guys...plus whoever they help.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
02-24-2016, 07:58 PM
Did you have a setting for "Trailer Sway" and was it on or off? Mine was off when I brought mine home. From what I understand that Trailer Sway and Traction Control are two different settings.
02-24-2016, 08:26 PM
Yes I did have sway control, and it was turned on.
02-24-2016, 08:40 PM
On 'high' but what number in the range did you find the sweet spot?
02-24-2016, 09:03 PM
That was a nice post CWSWINE. Good information, does anybody know if Chevy HD trucks have those settings?
02-24-2016, 09:23 PM
My impression is that depends on the weight of you 5er but mine falls between 7 and 8 most of the time. My new 5er weights in at 14,100 with gross combined weight of 22,320.
02-25-2016, 05:54 AM
My trailer sway was turned on.
Lee and Anne
02-25-2016, 01:00 PM
Don
Two settings in 2016 Ford F350
Thanks Everyone
Ever since I began towing my fifth wheel with my new truck I have complained that the braking was soft and didn't brake firmly enough for my taste. I have the gain all the way to 10. My DIC is listed as Low, Medium, High. Mine was set to Low. Changed it to Medium. Will see how it brakes next time we go out. Good info here. Maybe I should have read the owners manual better. I missed this little tidbit.
Happy Towing
02-25-2016, 01:22 PM
Well, I hooked up to the Silverback this morning and pulled it out of the barn. CW, with the DIC set on high, it would lock up the brakes at rolling speed in the driveway with the controller at 7.5 or higher. I ended up at 7.0. I'll check it at highway speeds tomorrow.
Thanks again. This was a big deal for me, because I was preparing to start pulling hubs to inspect/adjust brakes.
02-25-2016, 02:53 PM
Wow, what a great thread. I'm on my second Ford F-350 and have complained to my dealer about the poor braking with my 5th wheel attached. Wait till I show them about setting the DIC. Thanks for the great information.
Ron & Pat
Greentown Indiana
2014 F350
2016 Chaparal 336TSIK
02-25-2016, 03:35 PM
CDR USN Ret
My 3500HD allows you to set trailer brake bias by entering number 0-10 directly via the DIC. It can also be set using a manual slide switch on the ITBC.
The towing guide tells you how to find the correct setting (basically, while moving at slow speed (I think it is about 20mph), you move the manual slide switch until the trailer wheels lock, then back off slightly).
The guide also states that when towing a very heavy load, even max bias may not lock the trailer wheels.
Dually is not provided with sway control (I guess they figure its not needed with DRW).
Remember - trailer brake bias is road condition specific. Any time road conditions change, bias needs to be changed.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
02-25-2016, 03:49 PM
I like to set my brake controller up on dirt roads. Increase the level until the wheels lock and then you are good on pavement. Anyone else do this?
2015 Denali Duramax 2500
2017 Coachmen 229TBS
02-25-2016, 04:15 PM
Yes, I was wondering of the setting on your last 5er. The weight you had listed for it was similar. The Montana is about 40% higher. Thanks
02-25-2016, 06:21 PM
On my Crusader I set the DIC to "Medium" and bias to 8 and would lock the tires. When i got the heaver 5er I switched to "High" in the DIC and would lockup between 7 and 8 but won't lockup with the DIC set at "Medium" even with a bias of 10.
02-25-2016, 06:29 PM
Thank you!!! Our Cougar is just a little lighter than your Crusader and I set it at Medium 7.5 so that helps my comfort zone. I have adjusted to where it felt best but have not locked the brakes and hope I never have to. Towing 20K miles annually that day will probably come though. Thanks again.
02-25-2016, 07:51 PM
DIC
Anyone know if a 2015 F150 Lariat has these controls?
02-25-2016, 08:07 PM
You know it worries me to know that so any people are towing with Super Duties that don't know how to set them up. I am not trying to put anyone down we all need help sometimes myself included. Its just that, how many others, who are driving the millions of Super Duties that are out there, who are not reading this thread are driving without proper braking settings!
I have worked for dealers, there is little to no way of knowing all the vehicle settings for every vehicle they sell. Yes, you can find the the answers to most any question customers have. But only after you read their owners manual for them. They don't have the time to do this for every customer and many would not do it if they had the time.
It was super annoying working in Mercedes Benz/ BMW service center because no one would read their manuals. These cars can do zillions of things most owners are clueless about.
Anyway glad the word is getting out there about this. And a big thanks to those who spend their time helping others on this forum.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
