Old 02-24-2016, 02:58 PM   #1
CWSWine's Avatar
Setting Tow Settings in DIC
My Ford F350 in the DIC "Driver Information Center" if you scroll down to "Settings" then to "Driver Assist" there two settings for towing. The first one sets up "Trailer Braking" has three settings Light - Medium - High that affects trailer brakes and should be set to what you are towing. Mine was set to light and wouldn't lockup the trailer tires till I moved highest setting. Second one is "Trailer Sway Control" mine defaulted to off and set this the way you want it. Some people like on and other off so what floats your boat.
I'm not sure if all trucks have those settings but if does they need to be set.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-24-2016, 06:08 PM   #2
I never knew those settings existed. I just checked mine and it was set on light. I bumped it up to medium to see what happens next time I tow.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 02-24-2016, 06:29 PM   #3
CWSWine's Avatar
I think a lot of people don't know they exist, not even the dealer I bought my truck from. Did you check trailer sway was on of off? Mine was off but mine sat on the lot and who knows what settings were changed. If you bumped it be sure to check your trailer brakes on the next outing.
Old 02-24-2016, 06:54 PM   #4
Hey CW. Based on all the responses on the other thread, there are a lot of guys that aren't aware of these settings. I was one of them. Your description is accurate.
Thanks for the info. You've probably helped several guys...plus whoever they help.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 02-24-2016, 06:58 PM   #5
CWSWine's Avatar
Did you have a setting for "Trailer Sway" and was it on or off? Mine was off when I brought mine home. From what I understand that Trailer Sway and Traction Control are two different settings.
Old 02-24-2016, 07:26 PM   #6
Yes I did have sway control, and it was turned on.
Old 02-24-2016, 07:40 PM   #7
CaptnJohn's Avatar
On 'high' but what number in the range did you find the sweet spot?
Old 02-24-2016, 08:03 PM   #8
That was a nice post CWSWINE. Good information, does anybody know if Chevy HD trucks have those settings?
Red dog is offline   Reply With Quote
Old 02-24-2016, 08:23 PM   #9
CWSWine's Avatar
My impression is that depends on the weight of you 5er but mine falls between 7 and 8 most of the time. My new 5er weights in at 14,100 with gross combined weight of 22,320.
Old 02-25-2016, 04:54 AM   #10
My trailer sway was turned on.
Lee and Anne
