You can buy a lot of what you need on the used market. You still have to buy the tow plates new as removing them from a vehicle is almost never done. I have installed both of my own towplates and brake systems, you don't need a lot of tools but you do have to be relatively handy to install the plates on the car. Decent instructions, but holes have to be drilled, usually in the frame. You can save about 50% by buying a used towbar and brake system. As far as the brake system is concerned, the Fiesta has a curb weight under 3,000 pounds so in most states a separate brake system is not required.
Cheapest is a used tow dolly...no tow plates, just the dolly and some wiring and at less than 3,000 pounds, you should be fine.
2015 335DS
