03-08-2017, 04:28 PM
Setting up Equalizer 10K 4pt
If it is like the 14k I have, the socket will be required. [ATTACH]131383
The nut is completely recessed.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
03-08-2017, 04:34 PM
Who Dares, Wins
I am 99% sure it is, but mine is stowed away right now.
EDIT: Do like I did, went to the local trailer joint and gave them a few buck to tighten it up.
2015 Chevy HD D-Max
2022 Impression 315MB
03-08-2017, 04:40 PM
I just finished torquing mine down this past weekend. Yes, you need the socket. The nut is in the recessed area and won't accommodate a wrench.
2016 Vibe 245BHS
2011 Chevy Silverado 2500HD Vortec 6.0L
Equalizer WDH w/ 4-point Sway Control
03-08-2017, 04:58 PM
I simply wedged the handle end of a large crescent wrench in between the nut and the head. Worked great.
03-08-2017, 09:18 PM
Thanks alot folks... i'll start sourcing the 3/4 drive breaker bar and the 1-7/8" socket...
03-08-2017, 10:03 PM
Northern tool for the socket, harbor freight for the breaker bar. Less than $10 each.
2017 Nissan Titan XD CC SV
2017 Salem 27RKSS
03-09-2017, 08:35 AM
You will save money by just taking it to a local rv dealer to have it torqued to the proper specs (430 ft/lbs I think). I did that with mine.
03-09-2017, 01:55 PM
Make sure you get a thin walled socket...not much space in there.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
03-09-2017, 02:15 PM
X2 - unless you've got a giant torque wrench to go with it! (Of course, this assumes the RV place has a giant torque wrench, too! )
The torque wrench will set you back about $400!
Titan Torque Wrench — 3/4in. Drive, 100–600 Ft.-Lbs., Model# 23152 | Torque Wrenches| Northern Tool + Equipment
2011 Traverse LT, 3.6L, FWD
03-09-2017, 07:01 PM
Canadian Member
Torque = force (or weight) x distance. Using a breaker bar and a pipe extension you should be able to figure out how to torque it to the correct amount. For example, a 200# person standing on the pipe extension at 2 ft from the socket = 200lbs. x 2ft. = 400 lb-ft.
03-09-2017, 07:13 PM
Who Dares, Wins
Whose the smart guy.... THAT GUY! LOL
Thank you learn something new everyday.
2015 Chevy HD D-Max
03-09-2017, 07:20 PM
Canadian Member
Just don't blame me if you fall off the pipe extension and hurt yourself!
03-09-2017, 09:20 PM
Who Dares, Wins
I would too...
2015 Chevy HD D-Max
