Old 05-18-2015, 08:31 PM   #1
CWSWine's Avatar
Setup Up Hitch
First hook up with the new F350 and new Crusader 315RST. I using a B&W Companion hitch.
You can see the nose is a little high. I also measured the frame to ground at the front and back and it is about 2” difference with the nose being high. I have about 7 inch clearance between the bed rail and the camper. I can lower the hitch arms by one hole or about 1” and I have one more adjust on my pin box or would you just call it good? I have not towed with this truck so I don't know how it tows yet.
ID:	77392   Click image for larger version
CWSWine is offline   Reply With Quote
Old 05-18-2015, 11:13 PM   #2
Dave_Monica's Avatar
The camper's axles are the pivot point...you only need to lower the front 1" to be level.
Dave
hitch
