Old 04-27-2012, 05:39 PM   #1
4kmprs's Avatar
Shank Length and Hitch Rating
i would like to be able to drop my tailgate without disconnecting the trailer so i can access items quickly.
I had a 12" hitch/step extension that i used with my pop up, but it significantly reduced my tongue weight capacity.
has anyone purchased a long adjustable ball mount receiver that enable the tailgate to be opened?
if so, what length? And, did the longer adjustable receiver reduce your tongue weight?
thanks for any help you can provide
Kevin, Meg and DDx2
2012 Rockwood Roo 233s
2004 F150 Super Crew 5.4L 3.73 4x4
Days Camped 2012 = 42
Days Camped 2013 = 9 planned before April 1st
Local Ohio CGs - Punderson SP and West Branch SP
4kmprs is offline   Reply With Quote
Old 04-27-2012, 05:51 PM   #2
Herk7769's Avatar
An extension to your hitch will ALWAYS significantly reduce your tongue load allowed due to moving the force application point in the wrong direction.
Remember that maximum tongue load is based on the force exerted on the ball acting through a moment arm that goes to your tow vehicle's wheels.
Moving that force away from the wheels makes the moment arm longer and reduces the allowable force before the hitch/truck is overloaded.
This is a pictorial of how a WD hitch works, but you can see the relationship of the ball, wheels, and the forces involved.
Name:	How WD hitch Works.jpg
HAM CALLSIGN - KC3FFW
Old 04-27-2012, 07:58 PM   #3
bikendan's Avatar
it would help if you posted what you're towing with and if it has a factory receiver or aftermarket receiver.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-27-2012, 08:22 PM   #4
BeagleIL's Avatar
While yesterday was the first time towing the Roo, that is one of the first things I noticed when unhooking. I can't lay the tailgate down. Quite a bit of difference to our old Starcraft. Everything on this trailer is just a wee bit closer to the TV.
Mark, Jenny, Adam & Lucy
2013 Rockwood Roo 233S
2015.5 Silverado 2500HD CCSB with Duramax/Allison
BeagleIL is offline   Reply With Quote
Old 04-27-2012, 08:23 PM   #5
It would also help to know how much you need to extend the hitch to be able to open the tailgate. 3", 6",12" ???.
Along with what Herk was showing/saying is if you are using a wdh, you will have to increase the tension on the torsion bars to get the same leveling action on the tv which may require heavier bars.
Old 04-27-2012, 08:28 PM   #6
4kmprs's Avatar
i am towing with a 2004 f150 screw 5.4l 4x4 lariat with 18 in tires. factory tow package. eaz-lift with 1000 lb bars and single right hand friction sway.
7200# gvwr, 8,700 max tow
2 5/16" ball on 12" in adjustable receiver.
about 6" too short
gcwr 14,500 lbs
prodigy brake controller
max tongue 1000 lbs??? cant find it right now
3.73 axle
Kevin, Meg and DDx2
Old 04-27-2012, 08:48 PM   #7
Triguy's Avatar
Yes, and apparently by quite a lot (50%) if you believe this article.
Is the only thing you are hitting is the power jack and, if so, by how much? Some have turned the jack head around to make room for things.
A little out of the box here, but would you consider a new tailgate like the ones with a V notch that 5er owners use?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-27-2012, 08:56 PM   #8
Whomever was giving the answer was IMO shooting from the hip. If the man only extended it 1/2" or 1" there is no possible way it would reduce the load carrying capacity by 50%.
The V tailgate sounds like a good idea! Even if you got one from the junk yard and modified it yourself.
Old 04-27-2012, 09:02 PM   #9
4kmprs's Avatar
vgate is intriguing but i have a are tonneau cover
turning around motor is an option too.
will investigate both
Kevin, Meg and DDx2
Old 04-27-2012, 09:04 PM   #10
Is it hitting the jack or the bed ends? Youroo!!
led pad
