Old 02-28-2016, 08:34 PM   #1
john5646's Avatar
Sherline hitch scale
Anyone use one of these? Worth 138.00?
So I ordered one, and the 5,000 lb gauge also. With that I'm going to play with it at axles also. I'll compare those readings then to a truck scale. And just see how close the comparison is. If that works out then I'm thinking this could be very convenient...
Name:	ImageUploadedByForest River Forums1456713037.924266.jpg
john5646 is offline   Reply With Quote
Old 02-28-2016, 09:23 PM   #2
Out of Order
I have one...the 2000# model. Works great as far as I can tell.
todtc318 is offline   Reply With Quote
Old 02-28-2016, 09:26 PM   #3
Mr. Dan's Avatar
Do a search for Sherline and you'll see a pic of one posted today.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 02-28-2016, 09:28 PM   #4
CWSWine's Avatar
Going to use on TT or 5er?
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-28-2016, 09:33 PM   #5
I have one and made adaptors to weight either a tongue trailer or a 5th wheel pin wt. Also have the 2000# and 5000# gauges.
Name:	Sherline with adaptors.JPG
ID:	100711   Click image for larger version
Name:	Case for Sherline 1.JPG
ID:	100712   Click image for larger version
Name:	Case for Sherline 2.JPG
ID:	100713   Click image for larger version
Name:	Case for Sherline 3.JPG
Old 02-29-2016, 08:46 AM   #6
MtnGuy's Avatar
I have a 2000 lb unit. It works well after I make it "settle down". I will push down on the tongue several times to make that happen. If you just set the tongue down on the scale, it does not measure correctly until you move the tongue around a bit.
The Sherline scale is most accurate in the middle of the scale. If you expect a tongue/pin weight of 1000 lbs (+/- 400 lbs), the the 2000 lb. scale is the best option. If you are expecting a tongue/pin weight of 2000 lbs and up (maybe 600 lbs. down), then the 5000 lb. unit would be best.
OC, I like your setup !! If I get the new 5th wheel we are hoping for, I might do something like that. I will have to get a 5000 lb. gauge, though.
hitch
