View Poll Results: What method are you towing your 5W camper with your Short-Bed TV?
Slider Hitch 34 57.63%
Pivoting type hitch (Reese Revolution/Sidewinder) 21 35.59%
Other (Such as a tow hog?) 4 6.78%
Voters: 59. You may not vote on this poll
Old 04-09-2014, 07:06 PM   #21
Back to Shasta Camping...
Originally Posted by MillerTime View Post
Don't know what a "tow hog" is, didn't see option for fixed 5th wheel.
B&w companion (non slider) on a 6.5' chevy bed.
MillerTime- Future Sabre Handler!!
MillerTime,
Sorry I did not include non-slider hitch... I guess I just thought that no one would tow a fifth wheel trailer without some means to ensure that no damage was done to either trailer or TV during up to 90 degree maneuvering into or out of parking locations. My oversight.
Happy Travels,
B n D
His TV: 2014 RAM 3500 MC DRW 6.7 CTD AISIN
His RV: 2014 REDWOOD 38FL (House)
Her TV: 2013 RAM 1500 CC 5.7 Hemi
Her RV: 2010 VCross 20VFB (Camper)
Bill n Diana is offline   Reply With Quote
Old 04-09-2014, 07:32 PM   #22
Oklahoma Proud
MillerTime's Avatar
I mainly tow gooseneck equipment trailers. But between them and semis , I could count the number of times I've been close to 90 on my hands (and the trailers would be empty when doing this). And never close with a 5er.
With the rounded fronts and extended pinboxes, most trailers (rv 5th wheels) are able to be towed without a slider. That and the fact I dislike the strain on axles, tires, and suspention on a loaded trailer when turning even close to 70-80, ill just add a couple more points to my turns!
To each thier own!
Old 04-09-2014, 07:43 PM   #23
Rest and Relax's Avatar
Heartland 88 degree turning radius Curt 20K fifth wheel.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
Rest and Relax is offline   Reply With Quote
Old 04-09-2014, 07:56 PM   #24
Although I now have a long bed my last truck was a shortbed and had a slider in it. I was actually amazed at how sharp of a turn I could make without sliding her back.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 04-09-2014, 08:03 PM   #25
transamz9's Avatar
Originally Posted by BombDoc View Post
I think the point is, I don't need to worry about putting it anywhere! If you're good with no slider, then good on you. I prefer not having to worry about it, and I don't.
My point is, I don't worry about putting it anywhere because if it will go with a slider it will go without one if you learn to back the rig instead of taking the easy way out.
If you are good putting un-needed stress on your your trailers frame and axle, then good on you. I prefer not having to worry about breaking an axle or spring or wheel far from home. I've seen far more front fenders messed up on tv's than back windows taken out. Maybe someone should invent a 5er hitch that mounts to the hood so people can see the front of their tv and see to back the trailer too.
I can make it home without a back window but it will be hard to drag the 5er with a broken axle.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 04-09-2014, 08:03 PM   #26
Jjsav's Avatar
Reese Revolution!!!!
2018 Jayco Eagle 355MBQS
2013 Rockwood 8281SS 5W, Reese Revolution (sold)
2016 GMC 2500 Denali HD 6.6 Diesel
2016 Victory Cross Country Tour
2012 Toyota Tundra Crew Max (sold)
Jjsav is offline   Reply With Quote
Old 04-09-2014, 08:09 PM   #27
Forgot to mention I drive semi for a living.
Mark And Libby
Brampton ON.
Old 04-09-2014, 08:18 PM   #28
Crusadernoob's Avatar
Goose neck air ride pin box. I am so confused why every one wants to turn as tight as they can, the stress on your tires and axles is so great that I wouldn't want to do it even if I could, if I can't get it in to a spot without going 90 then I don't need to be in that predicament. My .02 worth
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 12
Crusadernoob is offline   Reply With Quote
Old 04-09-2014, 08:22 PM   #29
Oklahoma Proud
MillerTime's Avatar
Im with you! Why?
Old 04-09-2014, 08:26 PM   #30
Im with you! Why?
I don't believe anyone wants to turn 90 degrees but have the ability to do so safely
With or without a slider .
Mark And Libby
Brampton ON.
bed, tow vehicle
