Old 02-21-2013, 08:18 AM   #11
TURBS's Avatar
Originally Posted by fire View Post
2011
Sorry man, just glancing at your online numbers for your truck and trailer and without anyone at this point doing the actual math that camper and your truck is not feasible.
Old 02-21-2013, 09:56 AM   #12
Dave_Monica's Avatar
Further, to what Turbo said, the 1600 lb dry pin weight on the 8281WS will be around 1800 lbs with the camper loaded, which would about max out the GVWR on most 3/4 ton diesel TV's. Definitely too much pin weight for the Tundra.
If you want to know what payload capacity you have available for pin weight, head to the scales with the truck full of fuel, passengers and gear. Get a weight for the front and rear axles and total...remember that you have to add about 175 lbs for a sliding hitch to the rear axle weight. The payload capacity by GVWR will the difference between the truck's GVWR and it's actual weight. You could also look at payload capacity by the rear axle weight rating (RAWR) which would be the difference between the truck's RAWR and the actual rear axle weight. Don't be surprised with a numbers in the 1000 - 1200 lb range.
If the RV sales rep claims these are 1/2 ton towable, all he's looking at is the max towing weight not payload. When it comes to 5W towing, payload is always the limiting factor, whether 1/2, 3/4 or 1 ton (SRW) trucks.
Dave
Old 02-21-2013, 11:39 AM   #13
You do not need a slider with the sidewinder, but if you are removing the standard pin box and replacing it with a sidewinder, the sidewinder is heavier than the standard pin box. That said, the additional weight of the sidewinder is less than the additional weight of a slider so the choice is yours. I opted for the sidewinger on my 5'8" bed. I agree with Turbo.... look very hard at the trucks numbers. Yes, I pull my 5'er with a "1/2 ton" truck but they really aren't created equal. I looked long and hard to find my GMC equiped with all the extra towing equipment and the 6.2 engine. They are few and far between.
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
Old 02-21-2013, 02:02 PM   #14
Owner/Operator
RodeoGeorge's Avatar
When my 8289WS arrives, one of the first things I'll be doing is replacing the Reese Sidewinder Pin Box with an Ultra Fab Trailair Air Ride Pin Box. The reason. I tow with a 3500 RAM Cab & Chassis with a Hauler Bed, and I want to mitigate the trucks stress on the trailer due to the truck's weight and inertia. That's something that I've not seen mentioned on the discussions about the coupling mechanisms.
Not as much of an issue with the half and three quarter ton vehicles, but a heavy one ton will jerk that Pin Box around a lot more.
Just waiting to get the numbers off of the Pin Box on the 8289WS to ensure that I order the correct Trailair.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-21-2013, 03:16 PM   #15
Engineer of Crazy Train
ChooChooMan74's Avatar
Originally Posted by f1100turbo View Post
your kidding right ?
Turbs, be kind to the new kid in the neighborhood. :-)
Dude, great truck and great camper, but I think it is a little much for your truck. It is yours and you can do what you want. Others say the same with me. If you haven't purchased, hope you will look at your options again.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 02-22-2013, 03:07 AM   #16
what year is your truck?
2006
2013 Rockwood 8281SS
2006 GMC 1500HD 6.0L 4.10 GAS HOG!
Rochester, NY
rcnhoward is offline   Reply With Quote
Old 02-22-2013, 06:00 AM   #17
TURBS's Avatar
Well at first I truly thought he was joking.
Then realized he wasn't .
Apologies for that.
Turbs
Old 02-22-2013, 11:11 AM   #18
The RV makers do list some of the 5ers as half ton towable, they are not. My V-Cross 275 fiver has a GVWR of 9,980 lbs and with pin weight of just under 2,000 lbs, I would not even try that. Good Luck
whj77372 is offline   Reply With Quote
Old 02-22-2013, 11:17 AM   #19
Denver, CO
garbonz's Avatar
Roger that.
2017 Fuse 23T
Old 02-22-2013, 11:18 AM   #20
Denver, CO
garbonz's Avatar
Oh but how nice does the 275 VRL, work with a 2500hd duramax. It's just right, IMO.
2017 Fuse 23T
