Old 07-16-2013, 09:30 PM   #1
Sierra 292RL Excessive Sway
Hi, my name is Les. My wife and I just bought a 2011 Sierra 292RL. We absolutely love it. However we can not seem to keep it on the road. We have a Blue Ox Sway Pro system. I knew the front end on my truck needed work done on it, tie rods and such. Got all that taken care of and thought it was ready to go, took it out today for another test run and again going about 55-60 on interstate it started swerving side to side. Not as bad as first time on road but still enough to not want to take it on vacation in 2 weeks. 3000 mile round trip. I tried different load configurations on the WD bars but does not seem to help. I'm running out of ideas. Just out of curiosity has anyone else ever had any issues with this particular model. I know it's a stretch.
lespeggy is offline   Reply With Quote
Old 07-16-2013, 10:04 PM   #2
Experienced Newbie
Using a torque wrench, tighten the 3/4" bolts under each bar to no more than 90 foot pounds.
I have mine at 60
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 07-16-2013, 10:08 PM   #3
This model does not have the bolts to tighten. I saw that idea in another thread. I guess they must have just recently changed the design.
Old 07-16-2013, 10:10 PM   #4
I should add my truck is a 2000 f350 4WD with a 9' utility bed.
Old 07-16-2013, 10:14 PM   #5
Experienced Newbie
You are correct, they did just change the design.
The other thing to check is that you have approximately 12% (10 - 15%) of the
Trailer weight on the tongue
2014 Cougar 31SQB
Old 07-16-2013, 10:18 PM   #6
Sgt. Schultz's Avatar
Have you looked at swayprots ?
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
Old 07-17-2013, 04:26 AM   #7
Thanks for replies. At this time I don't have any thing else in truck or trailer. It is just dry weight. I may try loading some stuff in it just to check. I'm going to talk to mechanic today where I bought it ( Lazydays Florida ) and see if I'm missing anything. I wish I knew someone else that pulls a trailer and have them pull mine to see if they have same problem, or is it still my truck. But alas I don't.
Old 07-17-2013, 08:00 AM   #8
Fulltime family RVer
Have you ever been to a scale with the truck and camper? It sounds like, to me, that it may be helpful to get weighed to find your tongue weight and work from there.
ependydad is online now   Reply With Quote
Old 07-17-2013, 12:08 PM   #9
tanddc's Avatar
You need to find out your tongue weight. Also, what size bars are you using? You need to have them matched to your tongue weight. One might be tempted to get larger bars since you have such a large TV however that would be bad. They need to match your trailer.
Also, did you set up the hitch per the instructions? Both vehicles should look level. Again, because of your TV their could be a tendancy to set the trailer hitch high (another bad thing as it reduces your tonue weight).
We use a Blue Ox and don't have the greatest TV length to wheelbase ratio and it works great. No sway at all.
Most of all, you need to find your tongue weight in relation to overall weight.
tanddc is offline   Reply With Quote
Old 07-17-2013, 12:25 PM   #10
TomStacey616's Avatar
Also, did you set up the hitch per the instructions? Both vehicles should look level. Again, because of your TV their could be a tendency to set the trailer hitch high (another bad thing as it reduces your tongue weight).
I agree with everyone... esp this post... I also use the BlueOX swaypro and my chain is on link 7 from the bar.... nice bow in the bar too... NO Sway.. (i figured out my other problem.. air in the BFG tires, pumped up to 40lbs and now SOLID)... Anyway... Check your tongue weight.. by the looks of the spec on that trailer, it's around 740lbs for a dry wt of 7200..could need a few lbs..... and make sure you have a "bow" in the arms...
2010 Tundra DC SR5 TRD 5.7L towpkg (gone)
2008 F350 Lariat CC DRW 6.4PSD
2013 PT Tracer 3200BHT
BlueOX SwayPro (used when hauling cart too)
TomStacey616 is offline   Reply With Quote
