Originally Posted by MR.M
I have yet to come across an electronically controlled torque converter . one that will lock up by electronic controls . every torque converter I've come across has a preset lock-up set at a specific rpm . you can order torque converters that lock-up at different rpms . racers use them
You are confusing torque converter stall speed and TCC (torque converter clutch) lock-up. Two entirely different things, stall speed is determined by the design of the torque converter itself whereas TCC lock-up is 100% electronically controlled on every single electronically-controlled transmission made.
Stall speed is something racers want just right as it will allow them to either use a transbrake or the vehicle's brakes to hold the vehicle in place in gear while applying throttle to get the engine near peak torque so you achieve a better launch.
TCC lock-up programming varies by manufacturer and vehicle, but in most trucks the TCC lock-up happens around 3rd gear and is easy to tell when it happens as the engine RPMs only drop a little compared to a gear change. Once the TCC is locked most programming does not unlock it until back in the lower gears. For example, my transmission locks the TCC just after shifting to 3rd gear and keeps it locked in 3rd through 6th gear. Locking the TCC reduces heat in the trans since the torque converter is no longer slipping (fluid slippage = heat).
Some programming will unlock the TCC with light increases in throttle rather than doing a full gear change, other programming keeps the TCC locked in the higher gears and will downshift instead of unlock the TCC when more RPMs/power are called for.
TH programming does vary for sure. Some increases line pressure for firmer shifts to reduce clutch slippage (and reduce heat), some holds RPMs longer between shifts to help prevent lugging the engine and causing it to fall out of the power band, some do lock out one of the OD gears, etc. Best way to try and figure out what it does is to a) read the manual and/or b) experiment and see what changes with it on vs off.
