Old 07-21-2013, 11:14 PM   #11
wyo700's Avatar
That 6.2 is very similar to my 5.7 in my tundra. My toy hauler weighs about 6800 loaded and pulls great. Your loaded will be more but should tow the same. It the payload that will get ya. I'm right at the gvwr of my tundra but still under on my rear axle so I'm not worried about anything.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-21-2013, 11:37 PM   #12
BOBFIDY's Avatar
Just from my experiance.....the spring bars for the WDH come in at least 3 ratings.....8,000, 10,000 and 12,000 lb ratings. The higher rated bars will let you transfer more weight to the front of your truck if you can not get it to sit level when hooked up.
Good luck with your combo.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 07-22-2013, 04:35 PM   #13
My Salem should be pretty close to your model. I did upgrade to the 12k bars as the hitch weight was pretty hard on my crew cab. After some adjustments on the hitch i tow pretty comfortable. I try to keep my box light when hauling and dont overload my front pass thru storage. Power has not been an issue with my 5.3, but i won`t be entering any pulling contests!
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 07-22-2013, 05:25 PM   #14
RollingDownTheHighway's Avatar
you'll be fine until you hit a 5 mile hill, then you'll feel it, but you'll be fine. I pull a Shasta revere right now,with a 5.3L Silverado 1500 and on flat grounds and small hills its fine, its when I reach the hills in CT, I wish I had a bigger truck.
but overall, the 5.3 tows fine.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 07-23-2013, 12:36 PM   #15
Tundra 381 hp and 401 lb-ft of torque
Current GM 6.2 403 hp 417 ft of torque
New 2014 GM 6.2 420 hp 450 of torque
Super 8 is offline   Reply With Quote
Old 07-23-2013, 01:18 PM   #16
Camper Less Camping
Cajun Po-Boy's Avatar
WOW...nice bump for the '14 6.2
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-23-2013, 01:25 PM   #17
I experience the same towing our 5er, when it starts to pull down, I just reach for the gear shift. Haven't had a problem pulling in the Smokey's yet. Don't go up the mountains at 60, but I do stay up with most of the semi's.
Old 07-23-2013, 04:13 PM   #18
Peak numbers dont tell the whole story its where it occurs. Ill take 385ft lbs at 3600rpms all day over 400 ft lbs at 4400 as an example.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 07-23-2013, 04:25 PM   #19
Should have added, I limit it to 3600 rpm in whatever gear it's in. If that's not fast enough, the other folks can pass or tolerate.
Old 07-23-2013, 04:26 PM   #20
wyo700's Avatar
Tundra makes the 401 lb ft at 3500 rpm makes for very easy towing.
2013 Toyota Tundra
