01-21-2017, 02:15 PM
#21
From personal experience, that end of the safety chain is immaterial. It's the other end that matters.
FROG AR-0019-242
01-21-2017, 03:55 PM
#22
I correct myself on my post not 3/8 but 7/16 Sorry.
01-21-2017, 04:01 PM
#23
I added orange vinyl lettering to my WDH hitch to remind me to remove the sleeve after removing the hitch. Way to easy to forget. As for the safety chain I agree the the weakest link is the connection of the chain to the trailer.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
01-21-2017, 04:05 PM
#24
Professional Curmudgeon
Originally Posted by mzbrandi
My trailer is rated wet at 9,500. I would be scared to have a D-ring not rated for at least 2 times the trailer weight. If the trailer should get loose, I would think that the pull would be a lot more than the wet weight of the trailer.
Brandi
They wouldn't be supporting the full weight of the trailer. Unless, of course, your axles all fell off too.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
01-21-2017, 08:49 PM
#25
Originally Posted by Mr Havercamp
Your choice I guess but it looks like the standard one used on many trailers. It sure looks the same as was on my last 3. It evidently meets DOT specs or they would not be using them and I would bet it has stamped tags confirming DOT compliance attached. If you think those hooks are flimsy, both chains typically attach to the same piece of 5/16" or maybe 3/8" bar they bend into a U, and weld each end to the underside of the A frame tubes where they come together at the coupler assembly.
Sent from my SAMSUNG-SM-G891A using Forest River Forums mobile app
X2. And that bar isn't much; I believe it's the weak link in the entire system. My chains were too short and when I first backed into my driveway, you can see what happened. (The chains and hooks held up just fine!)
2011 Traverse LT, 3.6L, FWD
01-22-2017, 12:47 AM
#26
Oklahoma Proud
Here's the hooks on a couple of my trailers. They fit just fine on the hitch on my Gmc 3500.
01-22-2017, 04:34 AM
#27
No it is not Same here, my chains were too short also.
At least Lippert is consistent with their welds as can be seen in your picture.........S%#tty all the time. My 3 yr old grand daughter can probably run a better bead.
01-22-2017, 06:17 AM
#28
The hooks on my TT look just like MillerTime's, and they fit my '13 2500 easily. all I have to do is hook them on the side facing down. My work trailer has similar, yet smaller hooks, and I can still get them on, if I hook them facing UP on the sides. Also guys, there are 2 1/2" drawbars available. I got one simply because I couldn't stand all the rattling and shucking with an adapter.
David and Vicki
19-month-old English Springer Spaniel "Sadie"
2019 Silverado LTZ Duramax
2023 GDRV Reflection 150 226RK
01-22-2017, 06:25 AM
#29
I keep a pair of shackles under my back seat for this just so I don't forget them. Windjammer chain hooks are big enough that I don't need them.
Sunset trail and my 16 ft flatbed won't go, I need the shackles.
I don't guess any of my trailers have long enough safety chains, I barely have enough without crossing them. so I keep having people walk up to me and say "you know you're supposed to cross those safety chains, right?"
I test drove my truck probably 15 miles before making an offer. while the salesman was inside I was walking around it looking for flaws. The receiver insert was just laying in the receiver loose so I took it out and put it under the back seat. It's a wonder it didn't fall out.
The salesman came running out to me after we made the deal with one in his hand saying I'd need this, my honesty overcame me and I told him there was one under the back seat.
I put my union emblem in the receiver insert now with a locking pin to keep it from falling out when I'm not towing.
Also the hole in the 2.5" receiver and the insert is about 1/4" off from the regular 2" receiver hole. The USA flag I've proudly mounted in my hitch since 1992 wouldn't line up. The union emblem had enough material I could drill it out but my flag doesn't.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
01-22-2017, 08:34 AM
#30
This is what works for me and it is the best option for you:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bruce
01-22-2017, 10:45 AM
#31
That's a great idea. I've been lucky I didn't damage any vehicles driving behind me as I drove around for an afternoon with the sleeve just resting in there. Found it still there when I returned to the campground.
Back on topic, I've been able to get my safety chains attached, but where I have issues is with the emergency braking tether. Tried different D rings from a feed/hardware store similar to tractor supply and no dice.
Sean
'16 28DBUD
'16 2500HD Dmax
01-22-2017, 03:59 PM
#32
My brake tether has a loop on the end. I run the loop through one of the holes in the hitch, then use this "quick link" to connect the loop to the standing part coming from the trailer (i.e., "back on itself").
01-23-2017, 10:17 AM
#33
Not a fan of shackles, took FR connections off end of chains, did not work on GMC tv. Purchased a couple of hooks from Tractor Supply that fit just fine. The hooks came with a pin and cotter pin to secure the hook on to last link of chain.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
01-23-2017, 10:29 AM
#34
X2 on these and if you think your chains are too short, double up
Put a carribeener type snap clip on the brake cable and hook it on to the link makes it a lot simpler to hook up
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
01-31-2017, 06:52 PM
#35
All, Thanks for the suggestions. I ended up changing the hooks. I added one quick link to give me just a little extra length since I have to hook them on the back side of the hitch. The locking pin is in the way of hooking them thru the front holes.
Chuck Roder & Family '07 Surveyor SV-235RS & '16 Chevy Silverado 2500HD (Gas) Crew Cab High Springs, FL.
