Originally Posted by spock123
With truck off I hear a light noise. Nothing is on in the truck. Pickup cranks up fine. The voltage indicator is sitting at between halfway 9 and 14. The engine is not throwing a code. I can only hear the noise inside the truck. Any ideas
The map/gps runs even when the truck is off. You "light noise inside the trck" may be this sound. I checked with the dealer and was told this was normal.
I've never had a battery drainage problem from this, even after having the truck sit for two weeks.
Mine is a 2015 3500HD Duramax.
