Old 06-29-2015, 02:08 PM   #1
size matters?
I'm new here and new to towing anything larger than a tent trailer. I drive a 2013 tacoma double cab 4x4 with a four liter. this truck seems too work very hard towing my 2007 shamrock 21 rs. Is it just my imagination or is this truck too small
jeff21rs is offline   Reply With Quote
Old 06-30-2015, 07:05 AM   #2
etothepii's Avatar
Assuming you have the tow package, it looks like the type of scenario where you are ok on paper, but it doesn't translate to real life.
That is most likely because when you pack up with gear and people, you are right at the limit. Plus, the Tacoma has a shorter wheel base than a full sized truck.
I was in a similar situation when I drove a Nissan Frontier. It did the job, but it wasn't pleasant. It all changed when I got an F150 Ecoboost.
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 06-30-2015, 12:31 PM   #3
schrederman's Avatar
Unfortunately, in my humble opinion, a Taco is just not a good tow vehicle for a travel trailer. A pop-up might be OK but all the frontal area of a bigger trailer just requires too much hp and torque. The side area in crosswinds will be too much for the shorter, lighter truck to handle well. Add the problems of stopping if your trailer brakes fail and you could be spelling disaster.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 06-30-2015, 12:46 PM   #4
Left Coast
This is one case where SIZE DOES MATTER!
Old 07-01-2015, 09:59 PM   #5
Your issue is the amount of drag as opposed to weight.
Old 07-01-2015, 10:04 PM   #6
I had the same problem pulling my Roo 19 with a Traverse. Looks good on paper, but I was NOT a happy camper; as stated, it's more drag than weight. Bought the Silverado and it worked much better.
2011 Traverse LT, 3.6L, FWD
Old 07-03-2015, 02:50 PM   #7
AMG
I had a 2013 taco 4x4 sr5 v6 trd sport tow double cab etc.
I pulled ONCE a keystone 2014 238ml at a dry weight of like 3990. Fully loaded with all our gear and my motorcycle in the bed we had a lot.of gear so I'd guess 4700-5000lb trailer (below the max 6000 Toyota says) (i used air bags and a WDH) it worked. I went 400mi r/t. I struggled up the hills on I-10. I traded it in for a 2015 f150 w max tow. It pulled that trailer w ease.
Got a new 35' stealth wa2916 and now the f150 is going and getting a diesel 6.7l f250... Hope this is my last mistake.
Get the right tv
TH : 2016 Stealth WA2916
TV : 2012 Ford F-250 PSD
AMG is offline   Reply With Quote
Old 07-03-2015, 03:39 PM   #8
Georgia Frog Rally 2018
aceinspp's Avatar
Yep may be close to max towing. It's where a lot of folks make there mistakes buy more of a trailer than you TV can handle. Sales folks will tell you anything to sell ya TT. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
