Old 06-08-2014, 09:43 PM   #21
mikier's Avatar
I don't know. My 1st trip, with this set up, is 2 weeks away. I will definitely be going to a parking lot to see about this next weekend. Thank you so much for bringing this to my attention. It is something I would have never though about until after(if it is a problem) it cost me a lot of $$
Originally Posted by jevanb View Post
does you pin box hit the side of the bed when greater then say 80 degrees? mine is about 1 inch away from it when at 90 degrees I have the factory pin box but a different hitch (superglide)
Mike,Patty & Sampson
2015 Chevy 2500 4x4 Diesel
2014 Puma 230FBS
2003 Four Winns 245 Sundowner
mikier is offline   Reply With Quote
Old 06-08-2014, 09:53 PM   #22
The dealer may allow you to swap out for a shorter pinbox. That to me seems like the best solution. I did not think the stock pin box on my PUMA seemed abnormally long, so maybe you got a dealer that installed a longer one?
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 06-15-2014, 05:26 PM   #23
mikier's Avatar
I checked and I'm at about 1" on the side rails also. this doesn't really concern me. have you ever had any problems?
2014 Puma 230FBS
Old 06-15-2014, 05:27 PM   #24
mikier's Avatar
I went back to the dealer and they were speechless, they are contacting Reese Monday and I will let you all know what the response/outcome is
2014 Puma 230FBS
Old 06-16-2014, 11:25 AM   #25
jevanb's Avatar
I had to cut away the pin box cover a few inches where it overhangs the bed rails, It would prob be a issue it the camping spot is not level. I might trim more off when I get the time... but the metal box at the back of the pin box has more them enough room so that is a non issue (I hope)
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 06-16-2014, 07:52 PM   #26
mikier's Avatar
I trimmed the cover so it is flush with the steel. it looks just fine.
2014 Puma 230FBS
slide
