Old 03-13-2015, 04:21 PM   #1
M109Rrider's Avatar
Sliding hitch question
I pick up a Reese 16k manual slider I found for sale along side the road. I noticed today (1st time using it) there didn't look like there would be much room with the hitch back so I dropped the tailgate before I slide the hitch back. Sure enough had the tailgate been up it would hit the pin box. Is that common?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-13-2015, 04:39 PM   #2
dcheatwood's Avatar
Wow. Never had to use mine in my 6.5' bed. Swapped it out last year for standard legs but makes me wonder. It sure seemed like plenty of room tho. Glad you caught it in time.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 03-13-2015, 05:44 PM   #3
07 ThunderRoad's Avatar
The hitch is wrong for the truck set up. You either need to reset the hitch in the bed or you need to get the correct hitch. Check the Reese instructions for the correct setup of the hitch in the Dodge bed.
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 03-13-2015, 09:38 PM   #4
M109Rrider's Avatar
I haven't had a need for a slider either, only bought it because it was a good deal...lol. I do not have a manual for the hitch. I know my rails are in the bed where they are supposed to be. No other adjustments or "set up" I can do other than raise the hitch, I could stand a little more clearance. Must be due to the extended pin box on my trailer.
Jason and Billie
Old 03-13-2015, 09:49 PM   #5
Iwannacamp's Avatar
Hmmm. I have a 2005 Ram 2500 4x4 4dr short bed. Reese 30051 manual slider and no clearance problems. I never looked how close, but it doesn't hit.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 03-14-2015, 09:39 AM   #6
M109Rrider's Avatar
I adjusted my hitch up 1 hole. Will see tomorrow when we leave if it made any difference
Jason and Billie
hitch
