Old 06-04-2012, 11:42 AM   #1
ironj's Avatar
snap up bracket sliding?
Ok, i picked up new 318bhs this weekend. Dealer worked in a husky wd hitch with friction sway....just something to use to get it home untill i get a better one. Anyway, setup towed just fine, even in some nasty 50+ mph cross winds ( west texas). Im sure the tv helped a lot there, but when i got home i noticed the snap up brackets had slid foward a couple of inches? There is just one ' set screw' type bolt that secures bracket. Am i set up wrong or is there something else i should be looking for? Thanks!
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 06-04-2012, 11:50 AM   #2
pbrackney's Avatar
The bolt just was not set tight enough. Make the bracket is directly under the chain and tighten the bolt up. It should stay put. If it moves again you may have another issue.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 06-04-2012, 12:13 PM   #3
ironj's Avatar
thats what i figured, but the literature that came with the hitch says to make contact with the frame, then to tighten another 1/4 turn?? then in big bold letters, "DO NOT OVERTIGHTEN"??..so i was worried that i would cause more damage trying to fix the original issues...haha
