Old 12-17-2014, 05:14 PM   #11
TURBS's Avatar
Originally Posted by chaslorr View Post
We travel light with just the 2 of us so am always under the tow capacity.
Just curious, how do you know?
Old 12-17-2014, 05:30 PM   #12
It handles the trailer very well. Can cruise all day at 55 to 60 mph, gets it moving quite well also. Slows down a little on big hills but they all do that...and have no over heating problems. We travel light with just the 2 of us so am always under the tow capacity.
Me too!
Old 12-17-2014, 05:32 PM   #13
Sorry I am with TURBS on this one, I was pulling my 67 Lemans on a u-haul and I needed the tow haul turned ON! to move that thing around. Its that 3.23 gear that sucks. Car weight 3150lbs, u-haul trailer 2210lbs, 660 lbs over max tow-able
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-17-2014, 05:40 PM   #14
towing capacity
Isn't the towing capacity determined with only the weight of the driver in the vehicle and nothing else? So adding a passenger and anything else to trailer would soon be over the towing capacity.
bojangles is offline   Reply With Quote
Old 12-17-2014, 05:44 PM   #15
TURBS's Avatar
Not including dealer add on items after it leaves the factory.
These things are not included in dry weight.
Propane tanks full.
Battery.
Spare tire and carrier.
Sometimes tv's
Hot water heater full weighs minimum 40 plus lbs.
Etc etc etc etc.
Old 12-17-2014, 05:47 PM   #16
TURBS's Avatar
Originally Posted by OldCoot View Post
Me too!
I can bet the farm you weren't 1000# from being overloaded when you started filling your camper!
Old 12-17-2014, 05:57 PM   #17
And I will bet my tar paper shack, we'll never know! As long as it goes and stops, it's good enough for me. Doesn't sag in the back either. It may blow sky high Fri when we head to Fawn Ridge, but there are Chevy dealers close.
Old 12-17-2014, 05:59 PM   #18
TURBS's Avatar
I know ! I've done the math!
Old 12-17-2014, 06:02 PM   #19
Rrickim63's Avatar
Tow haul mode is recommended .yes it revs higher, keeps the transmission from overheating in the long term
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 12-17-2014, 06:05 PM   #20
davel1971's Avatar
tow mode also raises the pressures in the trans for tighter clutch engagement. Much easier on trans. You might not feel it, but your trans appreciates it.
David & Lynn
trailer, modifications
