Old 12-18-2014, 12:07 PM   #51
I'm having a hard time seeing why this is even being debated. It's tow/haul mode. Use it when you tow/haul. Seems pretty clear to me.
Old 12-18-2014, 12:08 PM   #52
TURBS's Avatar
I'm with you.
Old 12-18-2014, 12:17 PM   #53
Cant speak for other manufacturers, but Ford recommends Tow/Haul mode for accelerating from a stop, bumper to bumper traffic, terrain with lots of ups and downs, etc. And if you are on mostly flat highway (already at speed) they recommend you turn it off as a way to gain fuel mileage. As I understand it with my truck (6 speed auto, eco boost) the Tow/Haul will keep you in 5th gear, and if you shut if off the truck will then use 6th (which is why you get slightly better fuel mileage). That was what I was told by a Ford Tech.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 12-18-2014, 12:26 PM   #54
(Dry Huunday)
DreiHunde's Avatar
Doesn't everything get debated???
But I concur....pretty straight forward type of thing!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 12-18-2014, 12:32 PM   #55
Originally Posted by Jim in Halifax View Post
As I understand it the "THMode" is mainly for starting from a stand still...Tranny decides when it should shift....My 2014 Silverado 2500HD is quite and really helps to pull our CC Silverback 29......You should not notice anything once rolling on a level...may shift differently on a long grade...J
No. See my response to oakprk above.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-18-2014, 12:43 PM   #56
Both mine and my mothers EB (one 2011 and one 2013) use all gears regardless of tow/haul mode. I think your Tech might wanna study a little more. Tow/Haul, at least on the Ford's, is NOT an overdrive off button. They would technically have to lock out 5th and 6th to be an overdrive off button, though.
Old 12-18-2014, 12:44 PM   #57
B and B's Avatar
I can concur the statement that the Ecoboost Ford shown in TH mode stays in 5th more than 6th on moderate rolling terrain. Monitoring transmission temp it does run lower in 5th than trying to stay in 6th or hunt between the two all the time. Ultimately it is up to the OP to choose what is best for him.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-18-2014, 12:48 PM   #58
That is true for the Chevys too. Mine will stay in 5th most of the time when in tow/haul, but it will still get up to 6th, usually on downhills.
2010 Chevy Suburban
Old 12-18-2014, 01:11 PM   #59
mcmartinez's Avatar
My understanding is that in TOW it doe snot shift into overdrive. I use it sometimes, particularly on hills, but I don't see much difference. 2010 Ford F-150 Super Crew Short Bed Crew Cab 5.4L V-8 6-spd auto 2x2 - 9,800 Lbs. towing capacity. Pulling a 2703WS Rockwood Super Lite (6,400 Lbs. dry weight)
mcmartinez is offline   Reply With Quote
Old 12-18-2014, 01:28 PM   #60
mlong's Avatar
THe biggest thing I notice on my '12 Silverado 1500 is tranny temp. When towing up steep grades I like to have the tranny temp displayed. I remember one time I did not have the TH mode on and the tranny was nearing the 212 degree mark. I turned on TH mode and the temp dropped. I do notice shifting pattern changes but not much. I wish the manual shift would work in regular drive mode rather than needing to shift the level to manual shifting. When I ha my Hundai Santa Fe I could manual shift in regular drive so it was easy to anticipate when I needed to downshift to get more power just before a hill.
I always tow in TH mode now. I'd rather not burn up my tranny!
2012 Chevy Silverado Crew Cab Short bed 5.3L v8
2014 Prime Time Manufacturing Avenger ATI 27BBS
mlong is offline   Reply With Quote
trailer, modifications
