Old 12-17-2014, 03:06 PM   #1
Some thoughts on trailer tow mode
My tow vehicle, 2010 Sierra 1500 ext cab, 4.8, 3:23 axle, WDH with sway control, rated to tow 4700 lbs. My travel trailer, 2013 Rockwood Minilite 2109S, dry weight 3700 lbs. When I first began towing with this combination I used the trailer tow mode. I found it noisy and it seemed to keep the rpms too high most of the time for my liking. Now when towing I don't use it and guess what, it's much quieter, the truck seems to not work so hard, plus my fuel mileage is much better. I guess for my circumstances, trailer tow mode is overkill. I wonder how many other folks are using it when it's not necessary.
chaslorr is offline   Reply With Quote
Old 12-17-2014, 03:26 PM   #2
What gear are you running in? Wish GM had a way one could lock out overdrive.22
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 12-17-2014, 03:30 PM   #3
I just leave it in drive and let the transmission decide where it wants to be.
Old 12-17-2014, 03:59 PM   #4
Charliec's Avatar
I tow a 2504s with a F150 Eco with a 3.55 gear and don't really see much difference in the mpg or any noise. Sometime I put it in tow mode and sometime I forget.
Charlie C
2012 Ford F-150
2015 Rockwood 2504S
Charliec is offline   Reply With Quote
Old 12-17-2014, 04:18 PM   #5
Blackhat6mike's Avatar
Only tried tow mode once and don't need it. I haul approx 10,000 lbs with fresh water tank 3/4 full and lots of personal stuff. My max cargo load is 3,300 lbs and Flyer weighs 7,800. Truck handles it with plenty power left over. The additional exhaust brake is a blessing!
Blackhat6mike is offline   Reply With Quote
Old 12-17-2014, 04:32 PM   #6
chaslorr, I have the almost exact same truck as you ( mine is a 2009) towing that trailer is no problem once it is pack up with all gear and people?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-17-2014, 04:43 PM   #7
I think the biggest effect of tow/haul mode is accelerating from a stop. It will keep it in a lower gear for higher RPMs until you get to cruising speed. After that, not sure it really does anything worthwhile.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 12-17-2014, 04:46 PM   #8
TURBS's Avatar
Tow weight is 4700# and dry weight of trailer is 3700# ?
Average user added items are 1000#
Sounds like your at capacity and then some.
Almost always your over on cargo Carrying capacity before your over tow weight.........
Have you ever scaled your unit?
I use tow hual mode anytime pulling a trailer!
It's there to use for a reason.
Old 12-17-2014, 04:47 PM   #9
It handles the trailer very well. Can cruise all day at 55 to 60 mph, gets it moving quite well also. Slows down a little on big hills but they all do that. I get about 15 mpg towing also, and have no over heating problems. We travel light with just the 2 of us so am always under the tow capacity.
Old 12-17-2014, 05:12 PM   #10
tow-haul
Do you have a transmission temperature gauge? I would be concerned about overheating the transmission if not using the tow haul mode. It is there for a reason and I think that is one of them.
bojangles is offline   Reply With Quote
trailer, modifications
