03-11-2014, 09:38 AM
Sparks?
So every time I connect my work and play tow hauler to my truck there is a small spark at the connector. I'm not sure why. I am sure however, it blows the 30 amy fuse in the truck which provides power to charge the battery while the trailer is connected to the truck... Anybody have thoughts? Is it because the fuses in the trailer are in the trailer or because the switches are on? Thanks for the advise.
03-11-2014, 09:44 AM
There is a high draw item turned on or you have a dead short. I suggest turning everything off in the trailer before making the connection.
2014 Solera 24R
USN Retired
03-11-2014, 09:53 AM
thanks Mikegjax.... thats what I was thinking.... I'm going to replace the fuse tomorrow. I'll make sure everything gets shut off before I connect.
03-11-2014, 10:02 AM
Since you dont have your unit listed in your profile or on your signature line I'll give you two things to look at.
If you have a tt then follow your plug in cord back till you find a metal junction block.
This block may be up under the plastic underbelly and sometimes there's a little door to access it.
Open it up and make sure your connection is good there.
If you you have a 5er then follow your cord up under your pin box where you'll find the same box.
Good luck and post what you find.
TURBS
Sabre owners united!
03-11-2014, 10:07 AM
F1100 I've a a work and play 21vfb
03-11-2014, 10:37 AM
Has this "always" been the case with this camper, or is it something new that is happening?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
03-11-2014, 11:13 AM
That's a short term fix. If you want to find the cause of your problem,you need to start trouble- shooting both visually and with a VOM.
Repeated replacing of the fuse defeats the purpose of having fuses.
03-11-2014, 11:40 AM
I just bought the unit so I am still figuring things out. I was thinking that it may be doing it because stuff was turned on inside.
03-11-2014, 12:14 PM
Do you know for a fact that your truck is wired correctly? (Factory wired or aftermarket)
03-11-2014, 12:46 PM
aqua man Its factory wired so I'm assuming its not the truck side.... I've hooked other trailers up to it and never had any issues...
03-11-2014, 01:19 PM
So the 7 pin sparks when you plug it in. Its a new to you trailer, so your sure the battery in the trailer is in good working order?
03-11-2014, 05:01 PM
03-11-2014, 11:27 PM
JB It's supposedly a "new"battery. But I trust the dealer as far as I can throw them
03-12-2014, 09:00 AM
Id check to make sure the battery is connected properly, make sure there is no battery disconnect switch as well. If the wiring is in good working order, I can only think that the battery is either so low on power, or disconnected that when you plug in the trailer is drawing heavilly. There is the possiblity of a short in the 7 pin for the charge lead, but you have to start somewhere in diagnosing the issue.
03-12-2014, 09:21 AM
Always Learning
Would it make sense to plug the 7-pin into another truck to see if you blow a fuse in that one? Could it help isolate if it is your truck or your camper?
03-12-2014, 09:28 AM
Another thing to try to isolate the issue is to disconnect the wire at the battery and then plug in the trailer. If fuse holds, then issue is with battery as any short in the wiring would still blow the fuse. It could be the battery is so dead it draws a high load. Have you checked the water in the battery? have you charged the battery on battery charger?
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi (with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
03-12-2014, 01:26 PM
On a previous post you were looking for a brake controller and harness to connect to your factory installed connector. You mentioned you got what you needed from eTrailer. I assume you have installed this. Just to isolate the controller, unplug it from under your dash to ensure it is not the issue. I should not be but if for some reason eTrailer hooked you up with the wrong harness there might? be an issue.
If that is not the problem disconnect the plug, replace the fuse and then use a VOM to ensue you have 12v on the truck side and 12v on the trailer side. If either connector does not measure any voltage you can then check the resistance with the ohm meter to see if you have a short. This could be mis-leading if you have any voltage at all on the pins. Use the reference Trailer Wiring Diagrams | etrailer.com
Also as posted previous, disconnect the trailer battery to see if it is an issue. Do the trailer lights and other DC stuff on the trailer work? It would seem battery is connected correctly, especially if the radio works.
