05-12-2015, 01:02 PM
#21
Ambassador
Originally Posted by thebrakeman
After breakfast, you could be gone in 20 minutes...depending on when your coffee kicks in.
Lol! Oh the double entendre you got going there made me spew the coffee I was drinking. Pretty good!
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
05-12-2015, 01:15 PM
#22
Originally Posted by Soonermikel
We stay hooked up…no problems at all!
X2..but very seldom hook up sewer for 1 nighters.J
05-12-2015, 01:23 PM
#23
Don't the majority of vehicles have a relay that connects the 12V "hot" wire only when the key is on? You shouldn't be able to drain the truck battery meaning there is no need to disconnect the 7 pin trailer plug.
05-12-2015, 02:00 PM
#24
Well it depends.
We usually put a little water in the trailer tank and hook up the power cord and that's about it if the pad is pretty level. I unplug the trailer connector from the truck and put the stabilizers and tongue jack down. Keep it simple.
05-12-2015, 02:18 PM
#25
Always Learning
I'm curious now. I know I can run the camper off of the truck- but I am not remembering offhand if the truck has to be on/key in or not. I feel like it works even when the truck is off and key out.
05-12-2015, 02:28 PM
#26
Depends on space available. Electric. Drop front Jacks to stabilize some. Use water from fresh tank on short stops.
2018 Forester 3011 DS
05-12-2015, 03:19 PM
#27
May not be quite as level as you want but sure saves time.
05-12-2015, 03:25 PM
#28
5 secs is a good guarantee tho'.
05-12-2015, 03:28 PM
#29
Originally Posted by locogk
i unhook the truck to camper power cord so noting will spike
same way we do it.
labarn
05-12-2015, 04:06 PM
#30
Newer Fords, with the OEM Tow Package, have a relay that cuts the power to the trailer when you turn off the ignition. Those who don't have the OEM Tow Package may not have a disconnect relay. It all depends who did the wiring.
For overnighters we do not disconnect from the TV. No one has said anything about that yet...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
05-12-2015, 04:11 PM
#31
Gm is the same power is cut with key off.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
05-12-2015, 04:16 PM
#32
05-12-2015, 04:19 PM
#33
For 5 secs time, why take the chance? I have an old broken down 05 Silverado and I unhook the cord.
05-12-2015, 04:26 PM
#34
Have done it several times with the old Hybrid, had to be careful with kayak placement for the front bunk to drop. a block to side level, jack and rear stabs down, power hooked only if needing AC. would add a few gallons of water If I didn't before leaving the house. Wired our 7 pin to provide power only when the key is on.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
05-12-2015, 05:41 PM
#35
never have any problem staying hooked never even unplug cord from truck. sometimes run stabalizers down sometimes don't.
05-12-2015, 08:58 PM
#36
That depends on how early you want to take off in the morning. We usually stay hooked up!
05-12-2015, 09:52 PM
#37
We will almost always unhook the 5th wheel from the truck even for an over nighter even if it is only just disengaged JUST in case of any emergency. Never know when that might occur & can't always know help will be available - only time we don't is if we get stuck and can't find a campground and have to do a Walmart or truck stop.
05-12-2015, 11:38 PM
#38
We stay hooked up as well and do put the Tongue Jack down. I love Cracker Barrels RV spots and a good dinner and breakfast for their hospitality!
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
05-13-2015, 12:55 PM
#39
I towed a popup with minivans for 7 years, and these did not have that nice feature. So I'm used to just unplugging, just to be sure. If you are sure the systems are isolated, then yes, that's another few ticks saved.
05-13-2015, 01:02 PM
#40
My old Silverado would drain my battery if I left it plugged in.
Want to guess how i found this out?
So We always unplug the pigtail just in case, and wrap it around the electric jack since we put that down
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
