04-24-2013, 11:55 PM
#41
Originally Posted by myredracer
Around my part of the world, the government says you cannot exceed any one of front GAWR, rear GAWR or GVWR. They also say that the tow vehicle must have 1HP per 150KG (331lbs) of GVW. I haven't seen that before anywhere. Ford also says the same thing in regards to GAWR and GVWR.
Not sure why anyone would think it doesn't matter if you exceed the stated maximums. You might get away with it in the short term, but it's not going to do the TV much good over time by overstressing brakes, chassis, suspension, etc. Heaven forbid, if you ever do cause an accident and you end up in court, if Judge Judy asks you if you are even one pound over the manufacturers stated maximums, you will be liable and have the book thrown at you. Same goes for your insurance company because they will be looking for anything they can pin on you.
I had no disagreements with you until "Heaven forbid"
I have read similar comments like this here and on other forums invoking fear of the law and insurance companies. Your comment is pure speculation with no supporting evidence or facts. I don't believe you understand the concept of insurance and why we pay the premiums.
04-25-2013, 06:39 AM
#42
Interesting that one group rationalizes why they have faith in the manufacturing engineer's safety specs and the other group rationalizes why they tow with more faith in their own personal insight regarding standards.
Whatever helps you sleep at night, I guess...
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
04-25-2013, 07:03 AM
#43
Originally Posted by ependydad
OldCoot - you know very well that's an unfair generalization. I have a "big truck" and vehemently adhere to 60-65 mph max speed even if the posted speed limit is higher.
Not a generalization, but personal experience. I pull 60-65 and am always passed by motorhomes & 5ers running at least 5-10 mph faster. In the last 6 yrs going to FL and returning, I can honestly say that I have passed about 3 rvs on I95, but have been passed by literally 100's of 5ers & mh all going above the speed limit.
04-25-2013, 07:30 AM
#44
As always in these discussions "Caveat Lector" (Let the reader beware).
I felt like I was walking through a field of cow pies looking for a quarter.
What I do know for sure is that the only change between my 2008 GMC Sierra 2500HD Crew Cab and the 2010 GMC Sierra 2500HD Crew Cab was a frame change. My truck has a "C" frame and the 2010 has a "BOX" frame.
The BOX frame truck has a 1000 pound higher GVWR than mine with the same options (engine, trans, rear, bed and cab). Axles, tires, brakes, etc are identical.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-25-2013, 08:00 AM
#45
Since someone brought up the legality of not exceeding the sticker weight- according to statements by LEOs on other forums, there is nothing legally binding about the sticker on the door of your truck. That sticker doesn't even have to be there. Do you fear being sued if you change tire size? What about repainting the truck? Changing axles? Running different tire pressure? These are all things that are posted on the truck but are modified constantly by people. Of all the forums I've been on and seen challenges to produce even one instance of someone being overloaded and being sued I've yet to see one case.
04-25-2013, 08:01 AM
#46
Always Learning
Right, but that doesn't mean that people are speeding because they have a bigger truck. It means people are speeding because they're speeding. In my opinion, you're drawing conclusions to things that don't have any relationship.
If you've only passed 3 RVs - does that mean the 100s of 5ers were all big trucks within their specs? Or was it a combination of those within their ratings and those over their ratings?
And, I'm not sure how the MHs fit into this discussion.
04-25-2013, 08:02 AM
#47
Always Learning
Finally, like I said - I usually pride myself on avoiding dogmatic arguments. This is my last post to this thread.
As jtstrongman said.. apparently you can ignore this. New thread, new rules? My real agenda reveals itself!
04-25-2013, 08:06 AM
#48
The following IMHO are the easiest to read -
Each Canadian jurisdiction has similar wording but from my searching most seem to bury it in the Motor Vehicle act - Manufacturers set the Gross Axle Weight Rating based on requirements set by Transport Canada.
- “ Gross Vehicle Weight Rating (GVWR)”; the GVWR refers to the maximum weight a vehicle is designed to carry including the net weight of the vehicle with accessories, plus the weight of passengers, fuels, and cargo. .
- The GVWR is a safety standard used to prevent overloading. Manufacturers set the GVWR based on requirements set by Transport Canada. The weight on an axle can vary depending on where items are stored. .
- “ Gross Combination Weight Rating (GCWR)”; the GCWR, sometimes expressed as the maximum trailer towing capacity, may change with different engine, transmission, and differential combinations, and is normally found in the owner's manual. The GCWR is the maximum weight of the truck and trailer combined. The maximum trailer towing capacity is the maximum weight of a trailer which may be towed when your truck is empty (no payload), any load carried in the truck will reduce its maximum trailer towing capacity. “ Gross Vehicle Weight (GVW)” is the number of kilograms derived by adding the weights on all the axles of your loaded vehicle.
- . “ Net Weight ” is the weight of a vehicle that is empty except for the maximum capacity of fuel, oil, and coolant necessary for its operation. (ALSO referred to as “CURB Weight”)
exceeding the weights posted on the vehicle will open the driver to unsafe operation of a motor vehicle charges IMHO
For the farm hands:
When an implement dealer tows an implement of husbandry to or from a farmer, or when farmers do this themselves, they are not required to have a permit for exceeding the normal allowable width (2.60 m). They are subject to meeting the height and length provisions the Vehicle Weights and Dimensions on Classes of Highways Regulation ( M.R 575/88), and obtaining a permit for exceeding these dimensions.
Note: Dealer to dealer moves require overwidth permits, and are subject to the standard conditions pertaining to the movement of oversize loads. Escort vehicles are required when a load is over 4.6m in width in these situations.
Bottom line IMHO - The driver is responsible for the safe operation of the vehicle regardless of all other factors. - Just like safe speed is not the posted speed limit (that is just the maximum speed) cause a crash for driving to fast for conditions driver is nailed for imprudent driving etc.
Same for a pilot or captain of a ship it is the person in charge of the vehicle that takes the responsibility for its safe operation & for knowing what "Safe" is for their particular vehicle.
PT Avenger 33BHS-TE
2020 f-250
04-25-2013, 08:07 AM
#49
I find it odd also that according to the weight police here that with all the unsafe vehicles violating the stickers and being UNSAFE, why do we not see the highways & byways littered with wrecked rv's? Just asking. See a bunch of cars that are wrecked and wonder if they were overloaded (weight wise, not booze) also.
04-25-2013, 08:11 AM
#50
Well, they sure as heck couldn't be speeding with an overloaded small truck! DUH!
04-25-2013, 08:19 AM
#51
Passenger aircraft have similar standards. I wouldn't fly on one if I knew it exceeded the safety criterion established by the FAA... Jus' sayin'
Scratch sends...
'14 nights camped:
04-25-2013, 08:25 AM
#52
How would you know if it did exceed the limits, demand a wt ticket before boarding?
04-25-2013, 08:32 AM
#53
Always Learning
The most important thing that I want to convey is something I said in an earlier post - I don't care if someone else overloads their truck as long as they do it knowingly. Know how to calculate your payload. Know how to determine if you're overloaded or not. If you are going to tow overloaded, do it knowingly and within your own justification. It's just not for me.
But, riddle me this - where have you found that the manufacturer's publish that these are RECOMMENDATIONS since you're determined that's what they are?
What would you say they are?
I answered this in an earlier post - they are ratings. The owner's manual describes them as such. I'd still like to see your official documentation where they're described as recommendations.
No. They might not be safe at all with any load. There are worlds of people that shouldn't be driving at all, much less towing. And since there is no way of knowing a person's experience level, type of terrain where they'll be towing, type of load, whether or not pin weight is correct, if load is distributed evenly, or a myriad of other variables, I'm having a hard time understanding how you can be so dogmatic about the published numbers being THE point where you transition from safe to unsafe.
I know you changed your answer slightly, but I'll address part of this here. Given what you said above, you haven't said it nor do I believe you mean it - but it gives the impression that if you haven't towed for a long time, you shouldn't be towing. It gives you the chicken vs. egg scenario - how do you tow without experience? And without experience, you shouldn't tow.
But, to clarify - I have never said (nor event meant to imply) that you are SAFE if you stay within your payload specs. I've tried to say, given the same driver, same truck and different loads - you are safe r using equipment according to it's published designed-limits. I've never worked at Chrysler and don't have access to their test results, therefore, I have no idea if my specs are the absolute max, are 1%-100% underrated for the lawyers or other goblins. I don't know and therefore I choose to go by what is published.
I responded to this earlier and have reconsidered. I suppose you do have a point that, YES, a newbie would be safer with smaller load, but how far do you take that? If they have 2000 pounds of payload would they be safer with that amount than 2500? I'll go along with that. But wouldn't they be safer with 1500? 1000? So why give them the 2000 manufacturer number blindly? Why not reduce that? Is that the magic number? Wouldn't someone with no towing experience be safer driving a Prius to a cabin? I know I'm going to the extreme here, but I'm just trying to say that the number on the sticker is not the be all, end all, of a truck's capacity.
I obviously can't argue that a newbie may be safer not towing at all (I've seen some horrendous drivers in the past living and working in DC; heck- I was 16 once and unintentionally slide my sister's car off the road because I was mad one night). But, I'm not saying the amount of load makes them safer vs. less safe. With my 3,000 pound pop-up, I got sway bad enough on the highway to yank my Durango around yet with the 14,000 pound fifth wheel, I don't recall a scenario where I've felt like I was out of control.
All I'm saying is, given the same driver and same vehicle - yes, you're inherently more safe in a truck that's being operated within it's ratings vs. one outside of those parameters.
I'm a newbie and I'm a computer programmer - I don't know trucks. I can put fuel in it, maybe wrench on a couple of extremely simple modifications (bed cover, tailgate assist, etc.). I can't change oil, brakes and have never changed a tire. I had a learning curve when it came to topping up my tires and understanding the 2 pressure gauges on my air compressor. I'm exactly the guy who you do NOT want to say (in fact, I had people tell me)- "that 14,000 pound fifth wheel... yeah, you'll overload the truck but you're fine." You haven't quantified how much it's OK to overload by (10%, 1,000 pounds over GVWR, 2,000 pounds over GVWR- what's OK? When does it stop being ok?).
Now, being a book-learning computer geek- I'm now going to want you to show me the documentation where it says, "These are the design parameters and it's acceptable to exceed them by X." I don't know you from my uncle (or my wife's uncle in this case - "You don't need a dually. I have one, but you don't need one. They're too hard to drive. You shouldn't get one.") Well, my recent trip to the scales tells me that to stay within my ratings, I needed the dually.
The problem is- this documentation doesn't exist. I have to go by "your instinct and experience". In my world, that's just simply not good enough.
I'd at least like to hear what advice you'd give to someone in the ag industry that is constantly hauling various types of loads per my hypothetical. Maybe get a Peterbuilt to pull a lowboy just to be sure.
As I said in a previous post and at the top of this one - if you choose to overload your truck, understand that you're doing so and make it an educated decision. If I were in the AG industry, I imagine I'd know a heck of a lot more about trucks than being in the computer industry. If I knew a heck of a lot more about trucks, maybe I could justify overloading. I don't and can't. It's not for me.
O come on ependydad, at least have a little fun with it.
I truly don't find these "discussions" fun. There's nothing you say that will make me decide I should overload my truck. And there's nothing I say that will make you go, "Hmm, maybe I shouldn't tell everyone they are OK to overload their truck."
04-25-2013, 08:38 AM
#54
Always Learning
Sure they can:
Originally Posted by Ragin Cajun
Engine & Tranny are capable, unfortunately the truck's weight limitations are not enough for that camper.
Originally Posted by TTNewbees
(my edit- extrapolated from Turb's answer)Sounds good, that answers my questions. No problems being over payload capacity, keep length and total weight in check, thanks!
And, the most favorite one of the "weight police":
Originally Posted by Random_Weight_Police
Sure it can pull it, but can it stop it.
So, duh- people obviously believe it's possible.
Are you telling me that your truck can't get your camper up to 70?
04-25-2013, 08:41 AM
#55
Always Learning
04-25-2013, 08:46 AM
#56
Resident Masshole
Gotta say, it's always entertaining listening to people justify their decisions, right wrong or otherwise.
I'm a new TT owner. My F150 tows my 23SS just fine from a "feel" standpoint. And then I got on the scale and found out my rear axle was 200lbs overloaded. Quite surprising. And with that information comes the power to make a different decision (adjust the load, take less stuff, etc).
Is 200lbs overloaded (+5% over manufacturer spec) something to worry about? Probably not. But at least knowing where I'm at allows me to make an informed decision.
All you guys out there guessing, or throwing caution to the wind knowing full well you are overloaded, I hope you have good karma.
04-25-2013, 08:53 AM
#57
...Are you telling me that your truck can't get your camper up to 70?
Sure it can, but it is a very rare occurrence.
My only gripe is all the "Unsafe" declarations made here about weight with no regard to the idiots pulling rvs over 65 mph just because they are pulling with a dually or equivalent and are not overloaded.
You sure don't see underpowered, overloaded trucks pulling rvs 75+ mph is all I'm saying.
04-25-2013, 08:58 AM
#58
Always Learning
I don't disagree- I just don't entirely see how it's pertinent to the discussion of going over or staying within your ratings.
04-25-2013, 09:00 AM
#59
I'm sure you somehow think your point is valid as result of your logic.
As a former military aircraft crew chief, I'd be busted if I knowingly overloaded your plane. In a subsequent court martial I could defend my actions by stating 'my standards make more sense in my opinion'.
And if you were judge, you'd somehow find that logical and humorous...
Scratch sends...
'14 nights camped:
04-25-2013, 09:40 AM
#60
We all be like:
LOL....exactly!
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
