Old 04-20-2012, 12:50 PM   #1
Steering Problems
Anyone have an issue when putting a load on your vehicle (2012 Nissan Titan 5.6L) & pulling a 2012 Flagstaff V-Lite 34.5 ft TT that the steering wheel pulls to the left.
V-Lite is offline   Reply With Quote
Old 04-20-2012, 01:18 PM   #2
jtstromsburg's Avatar
What are you using for a wdh and sway control? Sounds like maybe it's not set up properly?
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-20-2012, 02:50 PM   #3
Dave_Monica's Avatar
Check the hitch manufacturer's instructions on line for set-up. It doesn't sound like your hitch is set-up properly...probably need more weight distributed off the rear axle.
Dave
Old 04-20-2012, 03:17 PM   #4
Are both bars the same wt, are they hooked with chains and if so, are you hooking them in the same link? If it doesn't pull when not towing you definitely have something out of kilter on the hitch.
Old 04-20-2012, 11:22 PM   #5
I'm on a mobile app, so I can't see if you have anything in your signature.
I have a 2008 Titan. I had a similar issue. I run an Equalizer brand WD hitch. I had too much weight distributed which also created too much friction in the antisway action. If I made a sharp left turn to get on the highway, I had to keep the steering wheel turned a little to the right as I drove down the highway. If I made a sharp right turn to get on the highway, I had to keep the steering wheel turned to the left as I was driving down the highway.
Basically, I had so much friction in the anti-sway that the truck and trailer could never straighten out. Once I corrected that issue, everything was fine. I just had to follow the directions in the manual.
2014 Flagstaff V-Lite 30WTBS
2016 GMC Sierra SLT 2500 Crew Cab 4x4 Duramax
2008 Surveyor SV-234 (SOLD, but not forgotten)
2008 Nissan Titan Pro-4x crew cab (SOLD, was a great truck)
smithmdsmith is offline   Reply With Quote
