Old 05-22-2013, 04:45 PM   #1
Suggestions for set up
I am looking for ideas on what type of tow set up you might suggest. I will be towing a 2014 rockwood 2306 and I have a 2005 4x4 dodge dakota with a v8. It has a tow haul mode, but I am not sure if it has a "towing package". I am not sure what exact v8 engine it has in it and I am not sure how you tell. Do you suggest an anti sway bar, weight distribution hitch, or anything else? What type or brand do you suggest. Thanks for any help in advance!
Jovebolou is offline   Reply With Quote
Old 05-22-2013, 05:19 PM   #2
Max tongue weight on that is about 715#.
Old 05-22-2013, 05:32 PM   #3
GoDuke1's Avatar
The engine is a 4.7L V8
2012 F150 SCrew EcoBoost
2013 Salem 27RKSS
GoDuke1 is offline   Reply With Quote
Old 05-22-2013, 06:25 PM   #4
asquared's Avatar
you need to run your vin. A dealership or calling dodge can do this. Ask them if you have the towing package and make sure it as the transmission cooler, if you don't you need to install a transmission cooler. You can look at the. hitch to check its ratings. you will definitely want wdh. A wdh with integrated sway like Reese dual cam or equal-i-zer with 800 lb bars would o you well since that trailer is probably gonna pretty near max your truck out.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
