Old 03-17-2019, 10:02 AM   #1
swj
sway
Sway problems, 2018 F150 3.5L max tow, supercrew -12000 tow capacity. Fastway 2 weight distribution 10,000 lbs hitch. FRiver Surveyor 251RKS 2017 trailer -6000 dry weight. Trailer sways at 55 to 65 mph. If their is any wind, trailer sways more. Makes for an unsafe ride.
Dealer has tried adjusting hitch several times, sway continues. Not sure if they know what their doing. First time I pulled trailer the truck was angled up, headlights blinded others. Trailer and truck are now level. 7 washers on hitch. It is almost impossible to take the bars off at a campsite.
Talked to another RV Dealer about a second opinion and they only service what they sell.
Is my truck and the Fast 2 hitch capable of handling this trailer or is the set screwed up?
Looking for a solution.
Thxs in advance.
swj is offline   Reply With Quote
Old 03-17-2019, 10:19 AM   #2
Daycruiser's Avatar
I think your hitch install and adjustments are probably your issue however I'm not familiar with that brand of hitch. Take your trailer hitched up to a trailer repair shop, not an RV dealer. You could also have an axle alignment issue with the trailer although not as likely. That hitch is pretty low budget from what I've seen online at $300 so don't be surprised if a good trailer repair tells you to upgrade the hitch and sway control.
Geof and Cheri
44 Years RVing and no end in sight.
2018 Ram 3500 SB Limited, CC, 6.7/Aisin, 4X4, SRW. Comfort Ride Energy Absorbing Hitch.
2020 Cedar Creek Hathaway 34IK, Reese 19K Sidewinder PB.
Daycruiser is offline   Reply With Quote
Old 03-17-2019, 10:19 AM   #3
Brother in Law had trouble when he got his Jayco with rear kitchen. Those trailers a heavy in the back and they packed even more back there. I had him try and move more weight to his front storage and front bed room and that took care of his sway problem. Try that before spending $1000's of dollars on other WDH's first. IMHO.
TheWolfPaq82 is online now   Reply With Quote
Old 03-17-2019, 10:22 AM   #4
007matman's Avatar
Something's not right. I have that hitch and it's great.
What are your measurements from both unloaded and loaded (front and rear) from.the ground to the middle of the fender?
007matman is online now   Reply With Quote
Old 03-17-2019, 10:29 AM   #5
We are pulling the same trailer same year with a 2018 F-150 crew, 4wd. We have a husky ts and have zero sway , easy to remove bars ( even without tool using front jack). 2 years of easy towing. Actual hitch weight is 825, scale weight 5880
palusza is offline   Reply With Quote
Old 03-17-2019, 10:34 AM   #6
swj
sway
A-truck uncoupled front fender is 36.5", B-coupled/no bars 37.25", C coupled with bars 36"
Old 03-17-2019, 10:40 AM   #7
Gold Tee Box
Teetime's Avatar
Do you have a Pic hitched up and level? If your tongue weight is good, and sway bars are that tight, it sounds like you may not be level and are getting aero under your camper.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
42 campgrounds/292 nights since 2015
Teetime is offline   Reply With Quote
Old 03-17-2019, 10:42 AM   #8
007matman's Avatar
Is the trailer level when connected?
Old 03-17-2019, 10:48 AM   #9
Was
You have plenty of truck. Those Fastway 2 hitches are junk. I had one and replaced it with a Hensley . No more sway
Was is offline   Reply With Quote
Old 03-17-2019, 11:09 AM   #10
swj
sway
Trailer standing level uncoupled, 30" front and 30" rear, The surveyor's A frame that leads to the hitch coupler is angled up several degrees, as the bubble leveler shows me, so the whole leveling thing is guess work... if i level the A frame the back is 30 inches and the front is 32 inches
sway
