Old 03-09-2015, 12:00 PM   #1
Sway Bar in the Rain
Took my new trailer for a test run this weekend. The helpful guy in the site next to me said that I should loosen my friction sway bar when it's raining. My route home was a stretch of highway heavily travelled by big trucks so I really did not want to disable the sway bar.
My setup is a Tacoma with towing pkg rated to pull 6500lbs and equipped with trailer brakes, a Rockwood 1901 at about 3800 GVWR, weight distribution bars and a friction sway control bar. Reading previous threads, the issue seems to be when turning, that because of slick streets the truck tires can slip due to the weight of the trailer pushing it. I am not an aggressive driver - very careful - but I am a beginner to towing. But it seems with my setup (weight of trailer being relatively low) that my risk from this issue is low. Seems that in the rain, I also wouldn't want the trailer swaying with the big trucks passing either so I'm thinking it is logical to leave the bar engaged.
Thoughts?
2015 Rockwood Mini Lite 1901
2017 Ford F150 EcoBoost
Terrib972 is offline   Reply With Quote
Old 03-09-2015, 12:30 PM   #2
stallsmi's Avatar
I always leave mine on in the rain with no issues. I have read, however, to disengage them in ice/snow.
stallsmi is offline   Reply With Quote
Old 03-10-2015, 07:31 AM   #3
Thanks stallsmi, for your response. I really hope to not be driving in the ice/snow! But you never know.
Old 03-10-2015, 07:39 AM   #4
The man knows of which he is talking.
We were towing our racecar trailer in Memphis in the rain with the dual friction sway bars tightened and going around a curve, we just about jackknifed due to the sway bars. We stopped and just loosened them a little and continued on with no problems. I never kept them tight in the rain again. Always stopped if we got caught in the rain and loosened them.
Old 03-10-2015, 08:02 AM   #5
rattleNsmoke's Avatar
Damn. Ya' learn something new every day.
rattleNsmoke is offline   Reply With Quote
Old 03-11-2015, 08:09 AM   #6
Thanks for sharing your experience, OldCoot.
Old 03-11-2015, 08:18 AM   #7
It sure opened our eyes and closed something else!
Old 03-11-2015, 10:33 PM   #8
acadianbob's Avatar
So, help me out here. Wouldn't the same thing hold true for an Equalizer hitch? How would that be any different?
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-12-2015, 01:03 AM   #9
Hi I always have towed with a WDH and a friction sway control tightened the same dry or wet. Never had have had control problem caused by the friction sway control. I have been dragging a 27' trailer since 1996 with my F350 for a lots of miles. What happens is my driving habits change drastically when the pavement is wet. Or high wind conditions. You need to slow down. Make sure you are looking down the road far enough to try and anticipate what you are driving into. If there is a curve in the road you may want to slow down even more to ensure the TV and trailer have good traction with the road surface. The harder it rains the less traction with the road the tires will have.
Hope this helps drive safe Tim
TimVWulp is offline   Reply With Quote
Old 03-12-2015, 08:41 AM   #10
We found the friction sway bars we used (EZ) when they got wet would tighten just like wet brake shoes will grab.
sway
