Old 03-31-2013, 05:52 PM   #1
sway bars
well i posted in the welcome section that we had put a deposit down on a salem, well we soon realized it wasnt going to work for our truck and ended up buying a shadow cruiser....
i understand this is a FR forum so I am sending my apologies early.
but we picked it up yesterday, a shadow cruiser 31bhs, its a great rig.
my question is the sway bars, when you put those on should you turn the handles all the way so they were tight? i put them on and turned 3-4 times, (dealer reco) and still felt some side to side swaying while driving home...just looking for opinions
Knepp1bj is offline   Reply With Quote
Old 03-31-2013, 07:51 PM   #2
bikendan's Avatar
it would help if you stated what you're towing with and if you are using a WDH.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-01-2013, 05:04 AM   #3
towing with a 2012 chevy silverado 1500...
wdh i would have to go back and look...it all came as a package deal.
Old 04-01-2013, 06:06 AM   #4
I'm assuming you have a friction sway bar since you mentioned tighten handle. I ran one for years and tighten as hard as I could go. They do not eliminate all sway and could if add 2nd one if you don't already have 2. After some use they will need to be cleaned with a wire brush. There are other options to help control sway through different devices. Look in etrailer.com.
2017 camped 35 days drove 6500 miles
2016 F250 Extended Cab PS
2018 Sandpiper 354RET
fkent1 is offline   Reply With Quote
Old 04-01-2013, 08:24 PM   #5
I had 2 friction arms previously and hand tightened as far as they would go and backed off until handles were parallel to the arms facing forward. I remember reading those instructions. Make sure you loosen them before backing up and try not to drop them on a hard surface like concrete. The inside pads break off pretty easy.
2013 Salem 30KQBSS TT
Equalizer 4pt Hitch system-12K
2016 Ram 1500 Crew Cab Sport 5.7 Hemi w/8 Speed
Great Laker is offline   Reply With Quote
Old 04-01-2013, 08:33 PM   #6
kho6658's Avatar
I use two and tighten them as far as I can by hand. Two versus one will make a big a difference.
2016 Freedom Express 28SE
2017 F350 Lariat
Days Camped 2018 - 6
Days Camped 2017 - 41
kho6658 is online now   Reply With Quote
Old 04-01-2013, 08:45 PM   #7
jlgail4309's Avatar
I knew my old hitch was set right when it made all kinds of noise turning a shape corner. That was as good as a friction hitch would do. Grinding and popping noise. I would start looking for a better hitch. If you plan on traveling a lot of miles.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
jlgail4309 is offline   Reply With Quote
Old 04-01-2013, 09:30 PM   #8
KDHfan's Avatar
When I got the walk through at the dealer, he told me to tighten it just until snug. It didn't take me long before I was tightening it as tight as I could get it and still be able to un-tighten. Made a huge difference.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 04-01-2013, 09:47 PM   #9
jlgail4309's Avatar
I put a open end on mine. And tightened up real good. I would get a second one to go on the other side. It about 50 bucks e trailer.com. under sway control. It's not going stop the sway all way. But it should help. Have u drove the trailer in the wind yet or trucks passing. Mine did ok with one or the other. But both high winds and passing trucks look out and hang on
Hensley Cub hitch ,
Old 04-02-2013, 11:56 AM   #10
i have 2 sway bars, one on each side.
i am going to try and tighten a little more on my next trip. thanks for replies, i am sorry i am not a FR owner for now and there are no shadow cruiser forums
