Old 03-12-2016, 12:42 PM   #11
Some guy in back...
I picked up our 8329ss last week-end and told the dealer NOT to transfer the sway control. I have a Reese garden variety WD hitch and wanted to see how the trailer towed without the "sway control" and also did not want my rails turned to Swiss cheese (I am installing a Hensley in the next few weeks)
My fairly long trailer towed very very well without sway control. I do tow with an E350 van with very short overhang from the rear axle to the hitch and so that is part of it, but I think the towing characteristics of the 8329ss are pretty good.
I was led to try this after towing my last trailer (Starcraft Autum Ridge 266RKS) with the anti sway hooked up but with out the friction adjust tightened a couple of times with no ill effects.
I'm not advocating that everyone should tow without some form of anti-sway, but I generally think the friction style devices we all use are rubbish. Has anyone seen a trailer delivered with an anti-sway device or any WD device, for that matter, in use?
Side note-I took the anti sway trailer-side mount off my old trailer myself and the bolts used were in there very well after two years. No rust (it's California) just tight. they were also not 1/4 20. The Reese manual I have says that they are "Screw, Self Tapping 24-9 x 1",...so very studly screws indeed!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 03-12-2016, 12:57 PM   #12
Originally Posted by bareftn View Post
why would you use self tappers? grade 9 bolts and nuts
Just about impossible to get nuts on bolts inside the tubing. GR 9? Maybe GR 8, but still no way of getting nuts on them.
Old 03-12-2016, 01:42 PM   #13
The bolts that came with mine were like they were made out of cast iron, and two of the four broke off on the tongue. I replaced them with steel and went another 80,000 miles with no problems after that.
Rick_Geneseo is offline   Reply With Quote
Old 03-12-2016, 01:44 PM   #14
Pilot holes were probably too small. Most have 6 bolts, never seen one with only 4, but no doubt the 4 bolters are available.
Old 03-12-2016, 06:47 PM   #15
Question what CW did wrong?
Originally Posted by beachcamper View Post
Camping world transfered my hitch to new 8329ss. Put sway control ball mount on with 1/4 20 self tappers. Self tappers heads are smaller than holes in mounting plate. Just pulled right through. Did last about 3000 miles.
There have been a ton of issues with CW locations around the country, but i can also say from first hand experience that most of the private dealers local to me are not much better, but i looked hard at your picture and in 300 miles i can not see how the holes in the mounting plate could be enlarged as much as they are.
I owned one of these sway controls 20 yrs ago and NEVER had a lick of issue with it other that using it so much it was about worn out when i traded the trailer in, but the sway control worked assume and could not tow the pop-up without it installed. I installed the whole thing from drilling the aframe holes to welding the adapter on the hitch and it never gave me any trouble.
Now i am very sorry this happen but again i do not see what CW did wrong?
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 03-12-2016, 06:52 PM   #16
Originally Posted by silverback 35ts View Post
...Now i am very sorry this happen but again i do not see what CW did wrong?
They used 1/4" self tappers instead of the 3/8" sheet metal bolts that have to have a pilot hole drilled. Very shoddy!
Old 03-12-2016, 07:01 PM   #17
Georgia Frog Rally 2018
aceinspp's Avatar
Or just maybe you tried to back up with out removing the brake as required. Never had an issue with mine when I had it. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 03-12-2016, 09:06 PM   #18
Broken Sway Contol
I use that identical setup on. 28RKS Wildcat. GW usually around 9000-9200lbs. Have well over 10000 miles on the setup now....no issues. Used the supplied self tapping bolts with no issue.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 03-13-2016, 12:19 AM   #19
The sway control ball mount had the 3/8 bolts in it when on my old trailer. Camping world technician lost them or just threw them away and used 1/4 20 tappers with tiny heads when reinstalling it. Probably didn't want to drill pilot holes for the correct bolts. Just drilled the tiny screws in and called it good.
beachcamper is offline   Reply With Quote
Old 03-13-2016, 09:54 AM   #20
WSY DD693's Avatar
I am with Mort & bareftn. What would possess them to use self tappers? Hardened bolts & equalizer is on my rig.
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
sway
