Old 03-11-2016, 05:53 PM   #1
Sway control broke off
Camping world transfered my hitch to new 8329ss. Put sway control ball mount on with 1/4 20 self tappers. Self tappers heads are smaller than holes in mounting plate. Just pulled right through. Did last about 3000 miles.
ID:	101674   Click image for larger version
beachcamper is offline   Reply With Quote
Old 03-11-2016, 06:46 PM   #2
Thats a lot of TT for a sway control like that. Did CW use the original bolts from the original TT? I would certainly think they would use new bolts. I would think the bolts would be at 3/8" bolts. Hopefully they make it right!
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is online now   Reply With Quote
Old 03-11-2016, 06:47 PM   #3
Better check the rest of your hitch out . Who knows what else they screwed up.
Big Red and 30WR is offline   Reply With Quote
Old 03-11-2016, 07:30 PM   #4
I replaced the bolts with 3/8. Don't know when it broke. Was traveling from Hilton Head to Charleston, SC up I95. Was windy. 25 to 30 mph gusts. Trailer towed like normal no sway. Just a little movement when trucks passed
Old 03-11-2016, 07:44 PM   #5
Casino Camper
jughrad's Avatar
My guess is they used the old hardware. I bought the EAZ Lift Sway Control - Right Side just like yours and I guarantee it isn't coming loose. I followed the instructions to the letter for the sway arm, I assume it was a CW error. There is a point in the video where I say 11/36 bit but I corrected later to 11/32 drill bit.
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
EAZ Lift 1000 WDH w/Sway Control
2017 Nights Camped: 39 Campgrounds: 12
2016 Nights Camped: 24 Campgrounds: 8
jughrad is offline   Reply With Quote
Old 03-12-2016, 09:42 AM   #6
firsthere's Avatar
I just installed the same sway control on mine. 1/4" tapping bolts don't use a 1/4" drill ,its 1/32 smaller, same with 3/8". Silicone behind the plate and in the bolt holes might help reduce the corrosion already apparent in the photo.
firsthere is offline   Reply With Quote
Old 03-12-2016, 11:48 AM   #7
schrederman's Avatar
I didn't use mine on my last trip. I towed about 400 miles with never a swing or sway. I had it with me and decided to not use it unless I started feeling some instability... never happened.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 03-12-2016, 12:06 PM   #8
Should have been installed with the 3/8" bolts furnished. I always tack welded mine in 4 places. Used the sway control on both sides.
Old 03-12-2016, 12:13 PM   #9
hitch
Get an Equalizer brand hitch.
mort is offline   Reply With Quote
Old 03-12-2016, 12:37 PM   #10
bareftn's Avatar
why would you use self tappers? grade 9 bolts and nuts
bareftn is offline   Reply With Quote
sway
