Originally Posted by Bikeski
Does anyone out there have experience with the Huskey Center Line hitch? Seems to work some what similar to the Hensley and Propride but half the price.
I do not have experience with that hitch and have only read up on it. There is actually not a lot of information because its not used nearly as much as others. Which is a shame because it appears to be a good system but most people (like yourself) would prefer more information from experienced users before buying.
My conclusion is that it is closer to the Equal-i-zer and Reese Dual Cam than it is to the Hensley. Most people say it does as well as the Equal-i-zer and Reese DC, but no one that I know says it does as well as a Hensley/Propride.
Note the Centerline reportedly has one drawback in that you must line up dead center with the trailer to hitch up. I recall one owner said he needs no more than 5 degrees from straight to install or remove the WD bars.
That would kill it for me as we camp often in sites that will not allow that.
Hope this helps.
