Old 05-02-2016, 08:45 PM   #31
We have a 30ft Rockwood. 2608ws bumper pull tv is 2013. 2500 Ram 4x4 mega cab use wd with added friction type sway bars. Have no sway problems at all. Friction sway bars worth the money. No white knuckle driving for us.
Joe-Barb is offline   Reply With Quote
Old 05-02-2016, 08:54 PM   #32
asquared's Avatar
Originally Posted by Hugeez View Post
Hello, I am checking on all the suggestions that were made to me. I do have E rated light truck tires but I'm sure they are not near maximum inflation. The max inflation is 80psi. Should I have them at 80psi when pulling my TT?
Make sure your rims are rated for that high pressure first.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-03-2016, 03:22 PM   #33
Hugeez's Avatar
I again wanted to thank everyone for their help and suggestions. I have another question. I have not done any measurements and I have read the manual on the E2 WDH but I'm not sure what adding or removing washers do to help equalize the weight on my TT. I think, and correct me if I'm wrong, that if you add more washers that when you set your round bars onto the L hangers that more weight is being transferred to the tongue of the TT. Once again, any help would be greatly appreciated.
Hugeez is offline   Reply With Quote
sway
