Old 05-02-2016, 01:26 PM   #21
jtesta1's Avatar
I was talked into purchasing one of those new fangled WDH with the built in sway control. one trip to Florida and I was back with my good old husky WDH with twin sway bars. 66 mph all day no sway even passing by big rigs are no problem . newer isn't always better. find what your comfortable with and stick with it.
jtesta1 is offline   Reply With Quote
Old 05-02-2016, 01:48 PM   #22
BigDaddy1967's Avatar
Originally Posted by tjm View Post
First off before you buy something something different, verify that you are set up correctly. Dealers don't always set the wd hitches correct right out of the box.
Sent from my iPad using Tapatalk
X2.
1. Check all tire pressure, make sure they are correct.
2. Scale TV and TV/TT with WDH activated.
3. Make sure weights do not exceed GVR, GAWR Front and rear.
4. Make sure tongue weight 10-15% of trailer weight.
5. Make sure WDH bars are correct for the load.
6. Increase or decrease bars tension, to transfer more or less load to front axle, then test tow.
If it doesn't get better, then I would consider a different make/model WDH
2014 Ford F250 Super Duty, 6.7L Diesel, Ultimate Lariet package
2016 Forest River, Heritage Glen 272RL
BigDaddy1967 is offline   Reply With Quote
Old 05-02-2016, 03:21 PM   #23
Hugeez's Avatar
Thank you to everyone who posted a comment or suggestion. I am going to check on several things that were suggested and let you know if anything helps. Thanks again.
Hugeez is offline   Reply With Quote
Old 05-02-2016, 03:49 PM   #24
Bowmanville SVT255S's Avatar
If that fails you have to 3/4 ton PowerDuraCummins with Air bags......Just kidding..good luck it dose sound over whelming..I have never done all of those things but agree many of us likely should..
2015 Ram Crew Hemi
2005 Surveyor SVT 255RS
Bowmanville SVT255S is offline   Reply With Quote
Old 05-02-2016, 04:45 PM   #25
V-Lite Fun's Avatar
Originally Posted by DDC View Post
X2. Wouldn't be without mine especially when the wind is blowing.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
https://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
Old 05-02-2016, 04:46 PM   #26
CaptnJohn's Avatar
You are joking of course. Everyone here knows once that popup camper hits your hitch receiver a 1 ton dually is required.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 05-02-2016, 07:37 PM   #27
Hugeez's Avatar
Hello, I am checking on all the suggestions that were made to me. I do have E rated light truck tires but I'm sure they are not near maximum inflation. The max inflation is 80psi. Should I have them at 80psi when pulling my TT?
Old 05-02-2016, 07:51 PM   #28
CaptnJohn's Avatar
Yes! I run 65 front 80 rear all the time on my F250. Dropping the pressure does nothing noticeable to the ride.
Old 05-02-2016, 08:08 PM   #29
V-Lite Fun's Avatar
X2
Old 05-02-2016, 08:08 PM   #30
And.. per my 2016 FR TT manual, there is a chart showing tire load limit vs. tire pressure. Basically, load limits are lower at lower tire pressures. Once I finally hit the road, I will be paying close attention to cold tire pressures. I do not want to be "one of the guys" pulling a TT that had a blow out on the road.
Old 05-02-2016, 08:45 PM   #31
We have a 30ft Rockwood. 2608ws bumper pull tv is 2013. 2500 Ram 4x4 mega cab use wd with added friction type sway bars. Have no sway problems at all. Friction sway bars worth the money. No white knuckle driving for us.
Joe-Barb is offline   Reply With Quote
Old 05-02-2016, 08:54 PM   #32
asquared's Avatar
Make sure your rims are rated for that high pressure first.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-03-2016, 03:22 PM   #33
Hugeez's Avatar
I again wanted to thank everyone for their help and suggestions. I have another question. I have not done any measurements and I have read the manual on the E2 WDH but I'm not sure what adding or removing washers do to help equalize the weight on my TT. I think, and correct me if I'm wrong, that if you add more washers that when you set your round bars onto the L hangers that more weight is being transferred to the tongue of the TT. Once again, any help would be greatly appreciated.
sway
