Old 03-30-2016, 08:43 AM   #1
Sway Control Options?
With trailers getting wider, taller, and sometimes lighter I have issues with my current rig which is a small hybrid Roo pulled by a mid size SUV using an old Reese WDH hitch and friction control sway reduction. I've pulled old 7 wide airstreams with full size vans and you truly didn't feel them behind you so. I've got a lot of options:
1. 4 point equilizer
2. hemsley sway control system
3. electronic sway control such as tuson or dexter
4. others?
So before I spend $500 or so on a new system what do you like and what hasn't worked for you.
Thanks,
Rob
DocRob is offline   Reply With Quote
Old 03-30-2016, 08:51 AM   #2
Mid size SUV? You really need to know all the Specs. on Both Vehicles to answer your request! Youroo!!
youroo is online now   Reply With Quote
Old 03-30-2016, 09:08 AM   #3
(Dry Huunday)
DreiHunde's Avatar
It would help!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 03-30-2016, 11:21 AM   #4
Sway Control Options.
Well the SUV weights about 3700 and the trailer weights loaded about 3300 with about 500 lbs of tongue wt. I'm not going to change out either one of them in the near future, so my question is as stated previously, what has worked for you and what hasn't. Anyone out there used the electronic sway control integrated into the trailer brakes. Don't tell me about how to set the hitch I've towed a dozen different combinations in the past so I know that part. What I don't know is if some of the new technology would make a difference.
Rob
Old 03-30-2016, 02:46 PM   #5
The Reese Dual Cam Sway Control may work with your current set-up.
I have it on mine and it was a NOTICEABLE difference in sway with/without it. the first review on e-trailer (Mike 1/2/2014) was by me and I still love it. I'm intrigued by the Hensley Arrow but can't justify the cost difference when the Reese DC works so well for my application.
Good Luck!
2006 Ford F-350
2014 Wildwood 28DBUD
Pick_PSD is offline   Reply With Quote
Old 03-30-2016, 03:32 PM   #6
4. others?
Thanks,
Rob
Well since you replied the way you did to our Questions,I can Very easy tell you that since you dont want to spend 500.00$ Items # 1-2 and 3 Cost way More than 500.00$ so you may still have to use your Reese WDH and Friction sway control! Youroo!!
Old 03-30-2016, 04:00 PM   #7
m2kamp's Avatar
3700lb SUV sounds more like a compact CUV.
I've been heavily researching WDH lately. You may be a good candidate for the Andersen Hitch. It weighs like 50 lbs and is apparently great for controlling sway and should handle your light tongue weight. Its the newest WDH technology and also costs about $500.
I think a hensley setup weighs like 200+ lbs and thats before you hookup your trailer so you may be exceeding your hitch capacity with that.
Hope that helps.
2015 Wildwood 26TBSS Equalizer 4pt 10k
2018 Ram 1500 CC 5.7L 4x4 3.92 LSD
2017 Ram 1500 CC 3.6L 4x2 3.55
m2kamp is offline   Reply With Quote
Old 03-30-2016, 04:41 PM   #8
sway control
Thanks guys,
I don't mind spending the $500 or more just don't want to spend it on a system that wouldn't work for me. For example I had no idea that the Hensley unit was that heavy and your right that would be a deal breaker. As for tow vehicle I have to be able to park in the city in a parking garage with small spaces so a big tow vehicle is out until I retire in a couple of years.
Old 03-31-2016, 07:49 AM   #9
Another vote for the Andersen. Haven't used one, but with something light, I'd definitely give it a try.
Old 03-31-2016, 07:56 AM   #10
Equalizer has worked well for me.
Equal-i-zer® Hitch - The “American Original” with 4-Point Sway Control™ and Weight Distribution
Brewhedd is offline   Reply With Quote
sway
