Old 06-16-2016, 03:35 PM   #1
Tacoma for pulling a Ultra Lite 2304S?
I have a 2009 6cyl Tacoma with the towing package and is rated for 6500 lbs although I would never pull that much. Does anyone have a similar Tacoma and has pulled this trailer, which supposedly weighs 3457 lbs empty? How does it do?
randy22556 is offline   Reply With Quote
Old 06-16-2016, 04:05 PM   #2
Had a 2010 Extra cab PreRunner pulling a 3003 empty Wildwood. Sorry to say, but it was not a capable TV on any grade larger than an overpass. Didn't tow with it long enough to notice any wind issues, etc. Traded her away.
bshort is offline   Reply With Quote
Old 06-16-2016, 04:52 PM   #3
bikendan's Avatar
That tow rating is for a flat trailer or boat, with no frontal area like a TT.
Air resistance is what most v-6 engines have trouble with, except an Ecoboost.
Equalizer WDH
Old 06-19-2016, 12:02 AM   #4
Ambassador
Ken K.'s Avatar
I just sold my 2015 Tacoma Prerunner SR5 it had a 6500lb max tow capacity. I towed a 2502KS with it. My TT's dry weight was 4500 with a 6K max cap. I towed that trailer about 10K miles in the year. I used a 12K Reese WDH with 1200lb trunnions. I also had to add Firestone Ride Rite air bags to smooth out the ride a little, only needed 25 psi in the bags, not to level but to cushion the bumps and bounces. They were no drill installation, so they were a no brainer. TV tires were a load range E BF Goodrich TA Terrains to limit the sway. I used 50Lbs in rear tires when towing. Once I did all this, and my WDH was set up correctly on flat land I hardly knew I was towing anything at all. I pulled it to the mountains crept up some steeper grades but maintained 55 mph or better on the normal rolling hills. I'm not sure if yours has an integrated electric brake controller. Mine did not so I used a Tekonsha Prodigy Trailer Brake Controller, it was proportional so the harder I pressed the pedal the more juice it sent to the trailer brakes. I didn't want the trailer trying to pass me when I wanted to stop. Finally I added a set of Tyger plug and play fold out tow mirrors I found on Amazon to replace the crappy factory mirrors that suck for towing. These made a huge difference. They were plug and play and bolted on in like 20 mins. Full electric mirror control. I was very happy with that setup never felt out of control. or felt like I was pushing the truck to it's max. Not even close. I did upgrade my TV to an F250 because I bought a big ass boat, and I'm seriously considering upgrading my TT to something more roomier as well. There were step by step videos for all my mods on youtube. You will find lots of nay sayers on here, truck snobs, hitch snobs that say you need a F350 with a v10 cummings, and an Allison transmission to haul anything. I did it for a year and 3 months without any issues. Just don't do anything outrageously stupid, and you will be fine. Happy travels!
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 06-19-2016, 12:17 AM   #5
Bluepill's Avatar
Remember that you have to add the weight of cargo (especially water) to the trailer. In reality, you will probably end up in the mid five thousand pound area.
Be careful on how the 6500Lb capacity is figured by Toyota. They often only allow for 2 passengers in the calculations, and more passengers and cargo in the truck need to be accounted for.
Old 06-19-2016, 02:37 PM   #6
I had thus TT I pulled with an 8 cylinder 05 4 Runner. Towing 7K. On secondary roads ok, but highway speeds / interstate, it was the tail wagging the dog. Enter tundra. Wow best vehicle ever owned.
robbdrell is offline   Reply With Quote
Old 06-19-2016, 03:12 PM   #7
I pull a Rockwood 2702SS, about 6000 lbs, with a '15 V6 Silverado. It pulls it fine although my engine is 285 hp. My concern with that size truck would be stability. You definitely would need a weight distributing/ sway control hitch like an Equalizer and the right truck tires.
Brewhedd is offline   Reply With Quote
Old 06-19-2016, 03:33 PM   #8
jhoppmann's Avatar
Had an '10 Taco and it had trouble in the hills with a Mini-Lite 2306. Could only do 40 mph some long grades and the trans was getting over 240*. Sold the Taco after the 2nd trip.
2015 Rockwood Mini-Lite 2306
2012 F-250 FX4 6.7 diesel
10k Equalizer Hitch
jhoppmann is offline   Reply With Quote
Old 06-19-2016, 03:35 PM   #9
Ambassador
Ken K.'s Avatar
you had set up isues
If you were tail wagging, you had weight distribution/ suspension/tire issues
Old 06-19-2016, 04:13 PM   #10
We have an '05 Tacoma with the tow package and a Tracer 205M (23 ft). We have towed over 10k miles. No problems, but we never go over 65 and have just us and the 9# dog in the truck.
Willietx
2010 Tracer 205M
2005 Tacoma Double Cab
Camping 2015 - 49
2016 - 73
willietx is offline   Reply With Quote
