Old 12-18-2010, 05:52 AM   #11
samsc03
" I am speaking of mid size pickups pulling TT's,1/2 -3/4 ton trucks pulling TT's and 5th's. If any one of them is to lose control they are not capable of doing the haul?"
Basically, yes. With a proper setup, one should never lose control on a dry highway. Ice, of course, is another matter altogether.
I have had blowouts and didn't even notice until I saw chunks of rubber flying out from under the trailer. I have been in panic stops and the trailer and tv stayed straight and true. We have been hit with a sudden 60 mph gust of wind (dead-on crosswind due to a massive dust devil), and all it did was move the truck and fifth over into the next lane, time span about one second. Unit stayed straight and true, no sway whatsoever.
That is a proper setup.
Old 12-18-2010, 08:32 AM   #12
samsc03's Avatar
actually it was more nose down ass up. Yes the hitch is attached to the frame directly and it is the heaviest duty hitch I could get.
Sam and Tonya
2011 Shamrock 19
2003 Toyota Tacoma V6 4wd
Tekonsha Voyager
Equal-I-zer
samsc03 is offline   Reply With Quote
Old 12-18-2010, 09:27 AM   #13
MtnGuy's Avatar
Sam, I think you will see a big difference in how your new trailer tows when you get your WDH and sway control properly set up.
A couple of things that you might consider:
Have someone thoroughly check your hitch to make sure it wasn't damaged by the twisting motion when your trailer overturned.
I think you stated that you have E rated tires on your Tacoma. Those have really stiff sidewalls, and wonder if that actually can hurt the towing due to the lack of flexibility. In my case, I have the P rated that came on the truck, but want to go with a little stiffer LT tire when the time comes, but I think an E rated tire will be overkill on my 1/2 ton truck.
Maybe Bobby (wmtire) can chime in on this.
Old 12-18-2010, 09:38 AM   #14
Anacortesians
I am continually amazed by the TV towing capability discussions. Folks in Europe have much higher tow ratings than the US does on the same vehicles. As an example - my US market 03 Kia Sedona is rated to tow 3500 pounds. The same vehcle in Europe is rated for 3000 kilograms (6600 pounds).
My uncle was an enthusiastic "caravanner" and towed about an 18' coach-built (wood frame, aluminum skinned) TT. In over 20 years (1955 - 1975). He never had an accident with the rig, even though he towed it with an Austin Cambridge (1.5L, 60 hp on a good day) and later with a short wheelbase Land Rover (similar to the Defender sold here, sxcept with a 2.0L 4-cylinder engine with about 85 hp). They went all over Europe with that set-up (Swiss Alps, Bavaria, French Pyrenees).
He was a fairly agressive driver without the TT hooked on, but with the very low power-to-weight ratio, he was awful slow with the TT on the back. Note that those vehicles had drum brakes all round, and the only brakes on the TT were surge brakes.
He was a memeber of the Caravan Club, a British equivalent of Good Sam, and they went to rallies just about every weekend. On the occasions I went along, I don't remember seeing anything bigger than a Mk IX Jaguar pulling a TT, exept one member who had a big V8 Dodge sedan. The majority used Land Rovers, even on the bigger TTs.
Frank and Eileen
No longer RVers or FR owners
Old 12-18-2010, 11:03 AM   #15
samsc03's Avatar
I always assumed the higher load range related to the more hauling capacity. It did keep them from flopping over when we were sideways and also not being completely down on the ground when the pressure dropped so low.
Definitely looking for the best frame shop in town to take a look at it. Especially the hitch area as the cab managed to meet the bed and that can't be good since it went back tgo where it was. The hitch back there does help sure up the frame ends I have always heard. Insurance for the truck is at 2,200 so far. Still waiting on the TT insurance for the final answer on what they will do.
Sam and Tonya
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
Old 12-19-2010, 07:14 AM   #16
MtnGuy's Avatar
With E rated tires on a Tacoma, you should have plenty of hauling capacity.....for the tires only. You still have the same weight rating on the axle.
In my case, I have P (passenger ??) tires on my truck that came as standard equipment. My rear GAWR is 3850, and each tire is rated at 2205. Even though I have 4410 lbs. of tire rating, I still only have a 3850 lb. axle. I like the little extra leeway with the tires, and I am not at the GAWR. The reason that I want to go with the LT tires when it is time to replace, is to go with something with a little stiffer sideway and little more leeway in the weights. I figure the slightly stiffer sidewall will help with my trailer towing. But going to something like an E rated tire, might actually be overkill. Those sidewalls wouldn't have much give at all, and would probably be way too stiff for my application. I don't think I would enjoy the rough ride, either.
Who knows, maybe the E rated tires saved your truck by not folding under during that wild sideways ride. But maybe they also could have contributed to the initial problem by not gripping enough when the trailer started to sway. All speculation here.
Old 12-19-2010, 08:04 AM   #17
samsc03's Avatar
Oh most definitely all speculation. It's all fine. I understand completely what you mean by the tires and the vehicles hauling limits. The reason the load range E tires stayed with the truck when we got the camper was beacause it did give me a very durable tire as well as not limiting the hauling capacity. I have never had grip issue with them in the dry pavement,I am sure I had more grip as the tire was going down but it was also creating the trigger like everyone here said. The truck has always rode like a board whether this suspension was on it or not.
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
Old 12-19-2010, 08:40 AM   #18
wmtire's Avatar
I am kind of coming in here at the tail end of this discussion. Can I ask what Load Range E tire you are using? The reason I ask, is that LT tires can have a thicker/wider bead area (to handle the heavier load stresses).
Rims made for Passenger (P) tires usually have a smaller bead flange, than rims designed for LT tires.
There are certain tires , like Goodyear G159, G169, etc......that do not perform well at all when placed on a rim with a smaller bead flange. You can get what is called bead rolling....where the bead tries to roll over the rim bead flange. This "can" cause handling problems in certain situations.
I'm by no means saying this was the cause of your problems, but just putting this onfo out there as a FYI thing for everyone to educate themselves a little on.
Old 12-19-2010, 10:49 AM   #19
samsc03's Avatar
Toyo Open Country M/T.
2011 Shamrock 19
Tekonsha Voyager
Equal-I-zer
Old 12-20-2010, 08:19 AM   #20
acadianbob's Avatar
You would have to be absolutely crazy to attempt to pull 6600 pounds with a Kia Sedona.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
