Old 03-23-2019, 01:32 PM   #1
Taking my new TT and TV on their first trip!
Hey guys, I bought a new TT in November and bought a new TV last week. I am taking them on their first trip tomorrow and think I got everything ready to go. TT is a 2019 29rkws and the TV is a 2019 Silverado LT 4x2 5.3l with the 8 speed trans.
Towing Specs on the truck are...
11,600lbs towing capacity with 2,102lbs payload capacity
TT weighs 7,148 dry and has a 770lb hitch weight.
Here is what I have done....
I added the air lift 5,000 ultimate helpers on my truck
Set up my Curt WD hitch using all current measurements. On flat pavement, the way I am loaded (which is fairly light as far as cargo goes), I am a 1/4 bubble low toward the front of the trailer and the truck is sitting almost dead level with 12lbs of air in the bags.
TT tires are at max cold
TV tires are at max cold in the rear and 5 lbs lower in the front.
Is there anything else I'm forgetting? I usually like to do a short trip with a new truck or tt to shake everything down but I don't have that choice this time.
Thanks!
2019 Flagstaff 29rkws
2019 Chevrolet Silverado LT
5.3L 8 Speed Automatic Crew Cab
Wd hitch
Air-lift 5,000 Ultimate air springs
Jmeyers278 is offline   Reply With Quote
Old 03-23-2019, 01:38 PM   #2
Sounds like you've done everything right.
If that tt has a roadside assistance plan, make certain that you've got all the information you need to call them in case something happens.
Bring a credit card to buy anything you've missed and have fun!
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 03-23-2019, 01:41 PM   #3
I appreciate it. I am just being as cautious as possible as I really have no clue how either will tow. This is a work/fun trip combined and I want to make it less stressful if I can. I brought my torque wrench to check the lugs at our first stop and tools to double check all of the bolts on the air bag system just in case
Wd hitch
Old 03-23-2019, 01:47 PM   #4
Let us know how it goes, I am interested in that TV too.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 03-23-2019, 04:01 PM   #5
Chief T's Avatar
Congratulations. Gotta ask though, but is there not a break in period for the new TV?
2017 Tracer Air 206
2012 GMC Sierra 1500 SLT 6.2l
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 11
Chief T is offline   Reply With Quote
Old 03-23-2019, 05:46 PM   #6
Itís past that. I leased it but it was the service loaner. Has 2,200 miles on it
Wd hitch
Old 03-23-2019, 05:49 PM   #7
markb5900's Avatar
Sounds like you did everything possible to be ready.
Have a great trip!!!
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 03-23-2019, 06:14 PM   #8
Those are dry weights. What are you loaded weights?
Also you need to measure the front of the trucks fender well to make sure you return enough weight. Using a level does nothing. How do you know the ground is level?
Ditch the air bags, they do nothing for weight transfer.
goduc is offline   Reply With Quote
Old 03-23-2019, 06:23 PM   #9
markb5900's Avatar
Don't like to argue but, when you put a level on the ground it is level or it is not!
For a normal, buy a Lowes level, being a 1/4 bubble off it just fine for any trailer or motor home.
Mark B
2017 GMC 3/4 Ton TV
Old 03-23-2019, 06:30 PM   #10
I prefer to measure the trailer frame at the front and rear. Takes all the guess work out.
I also measure the fender wells. Numbers don't lie.
I do use a level when setting up at the CG.
The reason I wouldn't use air bags with a WDH is that they remove weight from the spring bars. If using a WDH with built in sway control then you remove friction.
first trip
