Old 02-19-2015, 07:55 PM   #1
Palle man's Avatar
Tandem towing
Just bought a new Sabre silhouette. It's a 2015. The model is 291bhts. Does anyone have any experiance towing a boat behind this model? Our boat weights about 4500 with the trailer and has two axles. Any input is greatly appreciated!
Palle man is offline   Reply With Quote
Old 02-20-2015, 09:54 AM   #2
thebrakeman's Avatar
Nobody can even hope to help you without information about your tow vehicle. And even then, the legality will depend on what state you live in, and will tow thru. Fill out your signature lines with your truck info and location.
In general, that sounds like a lot of boat to be hanging off the end of a camper, even if your truck can handle the total combined weight (?).
thebrakeman is offline   Reply With Quote
Old 02-20-2015, 10:03 AM   #3
This is a Question best answered by the (Factory) they are the one to make the Call! Please reply what the (Factory) says,NOT the Salesman! Youroo!!
Old 02-20-2015, 10:07 AM   #4
Don't think he is asking whether his truck will pull it, just as to whether the trailer will handle hooking a boat trailer to it.
Old 02-20-2015, 10:42 AM   #5
TURBS's Avatar
And as I've already stated the factory says NO!
I'll even show the email.
Old 02-20-2015, 12:13 PM   #6
TURBS's Avatar
Directly from sabre.
From me,
Xxxx, does sabre even remotely allow a trailer of any kind to be towed behind a sabre 5th wheel in sabre or silhouette form?
Ron
From sabre,
No, If any alterations are done to the frame it can and will void any warranty coverage that the customer may have.
Old 02-20-2015, 01:01 PM   #7
avolnek's Avatar
I could honestly care less what the factory says about it, of course it will void the warranty... pretty much any modification voids any warranty on just about everything...
Many automakers void vehicle warranties with the use of a snow plow, but many continue to do it...
My awning warranty as well as many others have been voided by the modification of adding awning supports, yet it continues to be done by more and more folk...
The reason the manufactures of campers are voiding warranties is that they haven't spent the time to verify whether or not their campers can truly support the additional stress and weight of an additional trailer.
Many people shy away from this topic feeling that it is dangerous. Fact of the matter is that it can be dangerous, but it can be done safely as well. It would be up to yourself or for you to find someone else competent enough to verify whether or not this could be done safely and correctly in your scenario...
welding additional bracing and brackets to your existing frame may or may not feasible...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 02-20-2015, 01:06 PM   #8
TURBS's Avatar
the problem is the pin box.
IT IS not designed to pull the additional weight.
Might as well tear it all apart as well and stiffen it up while ur at it!
Awning modifications most likely won't kill anyone.
Broken pin box or frame quite possibly will if not caught.
TURBS
Old 02-20-2015, 01:08 PM   #9
avolnek's Avatar
Can you verify that Turbs? They all appear to be an industry standard for the most part installed in an industry standard fashion...
Old 02-20-2015, 01:10 PM   #10
TURBS's Avatar
ID:	69956Click image for larger version
turbs
towing
