Old 06-24-2011, 05:13 PM   #1
pip
pip's Avatar
thanks to this forum
before i bought a new wdh in march I did some research on this forum and found a lot of advice about checking the install after a dealer installs wdh, i would of never thought to do that. I bought a new equalizer 4 point hitch and checked the set up when I got home and found 1 L bracket at 31 " other one at 32 " and they only used 4 spacer washers, owners manual said start with 5. I put both brackets at correct space and after trying it out, I added 2 washers and now it pulls great, I'm now sway-less. THANKS FOR ALL THE TIPS & TRICKS.
2011 greywolf 26 bh - equalizer 4p
09 f150 super cab 4x4
pip is offline   Reply With Quote
Old 06-24-2011, 07:26 PM   #2
I had to completely redo my set up as well. Even the hitch ball was loose. My set up is great now and I learned a lot in the process. Remember to check the bolts on the link plates during travel and the socket bolts now and then.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-24-2011, 08:26 PM   #3
acadianbob's Avatar
There is an advantage to doing your own install. Then you know it is right and you know exactly how it works and how to adjust it.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
