Old 05-21-2016, 11:53 AM   #31
CWSWine's Avatar
Originally Posted by aceinspp View Post
Not really if you trade gas for gas it's all a wash unless your trying to trade gas for diesel. And now the new Chevy charge ya 8900 extra and if your using as a straight tow vehicle and not a daily driver it takes a long time to coup investment. Gas still cheaper and I do get close to 20mpg non tow with 4:10 gear. Later RJD.
Diesel is has hit rock bottom is Branson, MO ---
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 05-21-2016, 11:55 AM   #32
BandJCarm's Avatar
That's pretty cheap!!
Course, I'd never get my 40' trailer in there anyway!
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-21-2016, 12:16 PM   #33
gas all my life on my second diesel never gas again
locogk is offline   Reply With Quote
Old 05-21-2016, 12:29 PM   #34
Rarely tow, load under 10K, mainly short trips around town - get a gasser.
Heavy tow, load over 10K, long trips in the hills - get a diesel.
It ain't rocket science.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-21-2016, 01:12 PM   #35
Diesel Scare
I recently had an issue come up that was scary to say the least. We have a Sprinter Diesel based Solera motor home with about 10,000 miles. On our latest trip we had a check engine light show up on our way home. We brought the unit to Mercedes and were subsequently advised that we had "obviously put gasoline in the fuel tank" and had thousands of dollars in engine damage. After I protested furiously that it was not possible, I was told somebody would be in to evaluate my unit and test the fuel in three days. Subsequently I received a call to pick up my unit, at no cost, and was advised that there was a software problem, possibly from an update at the last service. I WAS RELIEVED !! While there I was advised about a M/B diesel sedan that was in for major engine work because the owner got a tank of mostly gasoline from a local diesel pump. I always try to buy fuel at major brand stations when on the road but the thought of losing my expensive engine because some careless refinery worker pushes the wrong button or hurried truck driver fills the wrong tank is troubling.
john.tucson is offline   Reply With Quote
Old 05-21-2016, 01:32 PM   #36
Telstar's Avatar
Keep renewing your warranty as long as you can. I have a 2005 F-350 with 109,000 miles and still under warranty. The 6.0 diesel design caused many problems, but thanks to the warranty none of the repairs cost me over $100. I still believe in the benefits of diesel. Wouldn't want a gasser pulling my 37' 5er.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 05-21-2016, 02:48 PM   #37
I`ve noticed with my 16 ctd that I get the same mileage pulling 2500 pound or 12000 pounds. I avg 13.5 . Does that sound normal ?
Big Red and 30WR is offline   Reply With Quote
Old 05-21-2016, 02:55 PM   #38
ARLO
Not all. We are going to v10 gas motors. Ford 6.0 and 6.4 diesels are only good for boat anchors. The 6.0 is so bad that ford paid out millions in class action claims. My personal vehicle is a ecoboost max tow. It tows my 6500lb trailer just fine over all terrains and gets 10 mpg towing, 16.2 around town and 21 or 22 on the road. With my wife driving it does a little better. Her foot must be smaller. If you are towing a monster tt or 5er, by all means get that diesel. If you are towing somethings under 7000lbs, a gasser properly equipped will do the jod
rlocicero is offline   Reply With Quote
Old 05-21-2016, 03:00 PM   #39
sfsgm's Avatar
Of course the costs will be higher. When you're putting in 12 to 14 quarts of oil each time, and a more expensive filter, that alone if enough to make a difference. And then there's the DEF. As somebody else said, buy it at WalMart for a huge savings.
Having said that, I've never had any major costs with a 2006 Ford F350, a 2008 F350 and now a 2012 F350. But then I guess I don't drive them long enough to accrue expensive costs.
I'll stick with diesels. But then trying to tow a 14,000 fifth wheel would be pretty tough on a gas motor.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 05-21-2016, 03:25 PM   #40
Is it just me or are some of these guys trying to make up for their shortcomings in other areas by bragging how badass their trucks are?
pacin is offline   Reply With Quote
diesel, maintenance
