07-25-2018, 09:21 PM
Theories - 2015 F350 Wont Roll in Drive
DW hopped in our 2015 F350 on Monday morning, backed up, put it in drive and something made it not roll fwd in D. DW theorized that something was binding rear wheel(s). She tried all kinds of things but never got it rolling forward. Ended up backing into a parking place to get it out of the way.
We had the truck towed to the nearest Ford dealership. Once it got there, it was perfectly fine. I trust that they ran every diagnostic they could think of but they found nothing. They wouldn't offer any theories.
This forum is great for for theories. What do y'all think could have happened?
07-25-2018, 09:38 PM
Aliens caused it.. LOL. Sorry, no help here.
Sounds Really odd.. wish I could be more help
07-25-2018, 10:28 PM
Man that does sound really odd. Did she pull it on down into other forward gears and try it? Just wondering , can't think of any explanation myself. Hope you figure it out.
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
07-25-2018, 10:50 PM
I had a friends car do that one time and the brake caliper had a bolt fall out. When he would back up it would catch the wheel and hold the car still. Go fine forward. We were going to pull the trans for a rebuild and noticed the caliper. I have also seen transmission sprags and carriers cause the same problem but if it is that it will show back up soon.
07-26-2018, 12:10 PM
Retired Member
Parking brake?
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
07-26-2018, 12:14 PM
I agree with parking brake... you can usually back up but not go forward with it set..
07-26-2018, 12:28 PM
I'm curious what the "all kinds of things" were that she tried. Like, was putting it back in park and then back in drive one of them? My old truck would do that on occasion. It felt like you hit drive in the response on the column but it would actually still be in neutral. Trying again, by shifting to park and then back to drive, would usually let it engage.
07-26-2018, 12:40 PM
did the engine race as in neutral? A lot of newer cars will limit the rev to ~3K RPM, nut it will get there quick. Or was the engine working and lugging even though not moving.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
07-26-2018, 01:59 PM
Originally Posted by rmwmiata
Parking brake?
That was my guess as well.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
07-26-2018, 02:12 PM
My guess is (if its an automatic) she slipped it into neutral instead of drive.
I'm teaching my son to drive and he has done that several times on our F-250.
07-26-2018, 05:24 PM
Thanks for all the theories. I'm going with the first response - aliens. ; )
All kinds of things include: turning it off, on again; putting it back in P. Going backwards in R for a bit, tries 4x4; set and unset the parking break several times.
I assume the engine was lugging, trying to get it to move.
I really hope it was pilot error w parking break or gear selector but am doubtful.
She didn't try lower gears.
Thanks again. If it happens again, I'll let y'all know.
07-26-2018, 05:41 PM
Parking brake?
X2 I have never used a parking brake on anything that I have ever owned except my Kenworth's
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
07-26-2018, 06:19 PM
I'm going to put my money on the transfer case. Some sort of electronic issue popped it into neutral.
08-02-2018, 07:57 AM
this is a Ford right?
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
08-02-2018, 09:41 PM
Descriptions are everything. I hate the call saying "the car won't start." Well does it turn over? Does it even click? does it turn over and spudder a bit? If it doesn't even turn over, do the headlights turn on and look bright? Each answer leads down a different path.
So in your case as mentioned, did the motor race like it wasn't even in gear? if not did it strain forward a bit like something was holding? If it raced then the truck was still in park or neutral or stuck between gears or you may have a neutral setting on the 4wd that might have been engaged. If it strained then something like the parking brake was holding it or a broken part internally but that wouldn't have just fixed itself. If it is a 4wd put it in and out of 4wd and 4wd low a few times an make sure that is still working. The parking brake can stick even if it's off, I'm not familiar with exactly how the 2015 Ford works but seeing as how it's supposed to be an emergency brake it should be a manually operated cable of some type, if it's been bent or pinched on a rock it might be hanging up.
08-02-2018, 09:54 PM
I don't have a 250 but have had similar issues if you don't think it's the parking brake.
Do you have 4x4? If you had it on and turned tight it will bind up and be difficult to move. You could turn off the 4x4 but it would not really release until it moved. If she backed it up it would release. Not sure if she tried it forward after that but once it moved it would have disengaged.
Good luck figuring it out.
