Old 08-17-2013, 11:49 PM   #11
TURBS's Avatar
Originally Posted by miknem1 View Post
Tires are crap i would need better ones
So what is the cargo carrying capacity listed on that sticker?
Old 08-18-2013, 12:02 AM   #12
wyo700's Avatar
gvwr on the door is 6700lb pay load is 1600lb pin weight on the fifth is 1500lb hitch weight on the jammer is 700lb. i did put air bag overloads on the truck. stupid question but why would they advertise a half ton rated fifth wheel if the smallest one will max out the half ton truck do they think people dont do research or that people wont care. i dont want to be that guy pulling the grape vine at 25 mph
They advertise that a fifth wheel is half ton towable because ya it may be 6000 empty and your truck has 10500 towing but like everyone has said it's your gvwr that matters. You will never ever reach your max tow in pounds and be under yours trucks gvwr it's almost impossible. One thing I have kinda figured out is take 80% of what is advertised as max tow and that is more realistic.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 08-18-2013, 07:35 AM   #13
Camper Less Camping
Cajun Po-Boy's Avatar
It's called marketing...that's why all sales talk is inflated & can't be taken as gospel until you do your homework on the numbers...math don't lie!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 08-18-2013, 08:11 AM   #14
I didn't notice that the 1360# I used was from dry weight That's way too low then. Also the 1500# you have is a dry pin weight. You need to use 15-25% of the 5er GVWR (includes the max cargo it can have in it). Don't forget to add in close to 100 pounds for the 5th-wheel hitch. That truck would be way undersized for the 5er.
Old 08-18-2013, 11:16 AM   #15
Fulltime family RVer
I will say, the new F-150 EgoBoost with max payload and max towing packages are boasting some impressive payload numbers. It's a lot of coin for a 150, but it has the numbers to support a lot more fifth wheel than most 1/2-ton trucks.
Doesn't help you, I know.
Old 08-18-2013, 11:17 AM   #16
The same as what Turbo and Barry said, just in article form:
http://learntorv.blogspot.com/p/what-can-i-tow.html
Old 08-18-2013, 11:35 AM   #17
Cargo on the door sticker says 1540lb but the truck has a car type tire on it right now. I ran over a pinecone and got a flat so im already looking at heavier tires
miknem1 is offline   Reply With Quote
Old 08-18-2013, 11:49 AM   #18
TURBS's Avatar
Keep in mind you can't upgrade the tires from p metric passenger style tires to lt truck type tires without upgrading the the wheels as well.
Old 08-18-2013, 11:51 AM   #19
TURBS's Avatar
The pin weight is 1500 lbs and you've all but used up your ccc before you even load anything in the camper or truck.
Not feasable sorry.
Lt tires or not.
Old 08-18-2013, 02:02 PM   #20
ok well thanks guys thats what i was looking for some real world answers. i will just roll with the truck and trailer i have and wait tell i can get a bigger truck. i really like the fifth wheels but i wanted to do my research before jumping into something that just didnt sound right in my head no matter how many times the salesman said "no you will be fine". thanks again everybody
trailer
