Closed Thread
Old 12-30-2015, 10:40 AM   #21
If the truck has the right tires I think I would try it with the addition of some Superstrings or airbags. It looks to be within a few hundred pounds of payload and that is very close. And if this is the 5er that has all the options and floorpan you love, then you can always upgrade the truck in the future if it doesn't pull as well as you like. If it is just a matter of it is the lightest 5er that may work but I don't really love it, I suggest buy a bigger truck and get the 5er you want. Don't "settle" for less 5er than what you want because you likely will just end up upgrading both truck and RV in the near future anyway.
In general, I am not a huge fan of half tons pulling 5ers but I readily admit I have no experience with the new Ecoboost HD half tons. There is a big difference between a half ton and a 3/4 or 1 ton SRW. Where you can easily upgrade many 3/4 ton trucks to 1 ton SRW specs, the same cannot be done with half ton trucks. Lots of differences.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline
Old 12-30-2015, 11:03 AM   #22
The Big Toe's Avatar
Yeah, we pulled my new XLR 29HFS back from Durnell's to his place in Michigan with his 7.3l Diesel. Dually. Stout truck. VERY stout.
I've been tempted many times to buy one -- Just to have it. I like them that much.
Power ain't the problem. Your excellent engine makes 250HP and 505 lb-ft of torque.
Torque is how much work is being done and HP is how fast it's being done.
The Eco-Boost has 365HP and 420 lb-ft of torque. Not shabby. And it makes its torque down low. Like a diesel.... Sort of
The suspension is what matters. And the brakes. And the tires. And the frame.
A 1/2 ton will never match what a Super Duty can do but if prepped judiciously, a 1/2 ton can surprise you.
The new ones are pretty amazing.
I'd still like to have a 7.3 I might do it someday and let it sit up North. Have to catch the DW in the right mood
The Big Toe is offline
Old 12-30-2015, 11:10 AM   #23
another_newfie's Avatar
Not enough payload.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline
Old 12-30-2015, 11:12 AM   #24
CWSWine's Avatar
Originally Posted by The Big Toe View Post
I think he's already got E load range tires, right?
Springs? No biggie. Just add air bags or a superspring (look out for that 5th wheel hitch). Two capabilities of superspring for the F-150. One stouter than the other.
I, being of the 'more is better' crowd, have the heavier ones and don't notice a bit of difference in ride. Neither does the DW.
Put them on myself. I could do it again in about ten minutes. All you need is a socket and 6" C-clamp. Initially, read the directions, pay attention to spacing.
Axles? It's a Ford. It's got a 9-3/4" rear end. The axles on that thing are already strong as grandma's breath. Stout. Compare favorably to the Dana 60..... Some say even better
Yeah, one model has 6-lug wheels and another has 7-lug wheels. Not sure if that's for the axles or for the wheels. If he's already got the 7 lug wheels, I'm not aware a bigger axle than a 7-lug. But....... There's a lot of things I'm not aware of. And the 6-lug is stout.
Look guys, with the utmost respect...... It requires no brains at all to tell someone to run out and buy a $65,000 Truck to pull a $30k Trailer. None. And I can't speak for the OP, but I don't have that kind of money. Those of you that do? Good on you.
To the OP: Why not consider a pull behind? You can easily go up to a 30' box and a 10,000lb GVW Trailer with that beast you've got to pull with.
Gotta remember, most 1/2 tons are specced from the factory to put ride quality over towing/hauling. But with some judicious upgrades, they can, IMHO, become very good tow vehicles.
Just my $.02
Ford has determined that standard truck frame isn't up to the task of HD Payloads and uses a heavy duty upgraded frame in the HD Payload trucks. Ford has used the excess in 2015 the lack of heavy duty frames is why the only produced a couple of HD payloads F150s in 2015. What about the frame payload limitations on the standard frame?
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline
Old 12-30-2015, 11:22 AM   #25
Link?
Old 12-30-2015, 11:50 AM   #26
B and B's Avatar
Hello OP Mr Acadian Bob,
You will have rear axle weight available, not a issue really. The payload is what your issue issue.
I towed 1900 lbs pin weight with my F 150. I was over on payload. The truck handled it just fine. I am not one to say do or don't. It is up to what you feel comfortable with. I never travelled with a full tank of gas to shave 150 lbs off payload and deleted as much stuff as possible to get it under the 1900 lbs. I did nothing to the truck but LT tires one size bigger to boot. I have a Super Duty now, good deal and definitely no issues.
I have seen many successful posts people towing Fifth Wheels with a F 150 Eco Boost, never seen a bad one.
It is up to you and what you are comfortable with.
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is offline
Old 12-30-2015, 11:51 AM   #27
MilCop4523's Avatar
we have an 09 Sundance bunk house 315 XLT 8320 lbs dry weight.
2013 Supercrew Ecoboost. 6.6 box
Reese 16K slider 5th wheel hitch
Added Firestone Rite Ride Airbags - although this does not increase towing capacity it does stabilize the load carrying.
changed P rated to LT tires - same thing for stability.
Just the wife and i travel - families meet us there - wherever there is...
we don't haul water either new or used.
trailer hauls better than our tag along at 6300 lbs
Dealership took truck specs and trailer specs, pin weight and figured we were well within towing ability.
Add driver and passenger total under 300lbs
Bedding dishes and pots/pans, limited food (generally buy items once arrived on site) and a TV, couple lawn chairs and sewer stuff and small odds and ends and still under weight.
we have hauled through hill country on the east coast this past summer and still blew Chevs and Dodges off on the hills - and yes - going up them.
no issues with the transmission overheating or dropping excessively into lower gears.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline
Old 12-30-2015, 12:02 PM   #28
Here's what I found..... It seems to me that your frame rail thickness depends on which wheel base you bought --
SUSPENSION:
Frame — Type Ladder Type with Fully Boxed Side Rails and Hydroformed Front Section,
7 Crossmembers, 36,000 psi Steel with 156.5" WB SuperCrew/
163.0" WB SuperCab
49,300 psi Steel with 126.0", 144.5" WB Regular Cab, 144.5" WB
SuperCab/144.5" WB SuperCrew
It goes on to mention a thicker frame rail but it looks to me like it STILL depends on which WB you bought....And it doesn't appear to be 'option specific'. IOW, you can't get the HD package in the lesser Wheel Base models...... To do otherwise would be putting the cart in front of the horse, IMO
8200-lb. GVWR is included with the optional Heavy-Duty Payload Package and requires either the 5.0L 4V V8 or 3.5L 4V V6 engine. In
addition to the equipment listed above, this package also includes Super Engine Cooling, 9-channel oil-to-air auxiliary transmission oil cooler,
frame upgrade (.150 rail thickness).
Page 86 https://www.fleet.ford.com/truckBBAS...12_F150_SB.pdf
Old 12-30-2015, 12:12 PM   #29
This is interesting --
http://www.ford.com/resources/ford/g...rv&tt_f150.pdf
(2) Vehicles equipped with 5.5' box will accept a 5th-wheel hitch, but current 5th-wheel trailer designs are not compatible with these models (133" wb. SuperCab and 145" wb. Crew Cab).
Old 12-30-2015, 12:23 PM   #30
MilCop4523's Avatar
I just read the same article... WTH?
and
Closed Thread
5er, f150
