Closed Thread
Old 01-01-2016, 08:23 AM   #71
Canadian Member
itat's Avatar
Originally Posted by wicked1 View Post
I have a 2014 F150 EB 3.55 with Max Tow, looking at Crusader 295 so weight and pin I am good have to get BFG's replacing Pirelli's and putting 2.5" air suspension in rear to level the rear when 5'er is attached.
My 2014 has 29K on it and I have a SCREW 5.5 bed with FX4 Package love this truck, also use it as an everyday commuter car
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
With the 5.5 ft. box you'll need a Reese Sidewinder (aftermarket) pin box on the 5er. I have the same size box and you can't put a slider type hitch in it.
Here's some advice from eTrailer.com for this situation:
"To determine if the Revolution offers enough extra clearance for your truck and trailer, there are some measurements to look at. First, measure from the center of the hitch jaws to the back of the truck cab and add 22 inches (length of Revolution extension). Then, measure the width of the trailer overhang and divide by 2 to get half."
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is offline
Old 01-01-2016, 09:25 AM   #72
CWSWine's Avatar
2015 Roo 23IKSS
I would watch the Crusaders the specs seem to run low compared to real life weights. Mine on the web said dry weight of 9950 and dry pin weight of 1950. I add 1180 lbs to the 5er over dry weight and my pin weight jumped from 1950 to 2780 on the scales and from 19.1% to 24.1% of trailer weight. On the 295RST I would plan for pin weight between 1700 and 2000 lbs on the scales with 295RST so added at least 500 lbs for hitch, passengers and misc in truck you probably need a 2200 to 2500 payload on you truck to be with payload specs.
At the time I had 2500HD 3/4 ton and come within 200lbs of max axle weight/tire ratings and 800lbs over payload.
Read this and give some additional information.
http://fifthwheelst.com/2015-half-ton-truck-towing.html
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline
Old 01-01-2016, 03:36 PM   #73
asquared's Avatar
This thread has gotten way off track. Site Team has had to do a clean up here. The OP has gotten his info. We are closing this one.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline
Closed Thread
5er, f150
