Closed Thread
Old 12-29-2015, 11:55 AM   #1
acadianbob's Avatar
This 5er with an F150?
Tow Truck:
3.5 Ecoboost, 3.73's, Max Tow, 1820 payload, LT Tires
5'er:
GVWR 8,043
Hitch Weight 1,043
UVW 6,556
CCC 1,487
Exterior Length 25'8"
I realize that these are dry weights not "wet" and optioned.
Cherokee Fifth Wheels / Travel Trailers by Forest River RV
Not interested in discussion about 250's, 350's, diesels. Just is this a reasonably workable combination. It seems workable to me.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is offline
Old 12-29-2015, 12:15 PM   #2
KMP44's Avatar
Get a dually...kidding...
Close on payload, but seems do-able. Gross weight of the trailer is pretty reasonable and it has great ccc, so you can minimize the cargo weight you put into the truck. Nice looking rig.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline
Old 12-29-2015, 12:38 PM   #3
CWSWine's Avatar
I plug in your payload and made some guess - 200 lbs driver 150 lbs passengers 100lbs of other stuff in the truck and in the bed and hitch weight and this is what I come up with.
"You're adding approximately 700 lbs. to the truck. You have 1,120 lbs. of payload capacity. Fifth wheels typically have 20% - 25% pin weight which gives you a maximum loaded camper weight of 4,480 - 5,600 lbs."
Here is the web page I used and the numbers is used.
Towing Calculator based on Truck's Payload/CCC - Towing Planner
I believe the Towing Planner is written by member of this forum.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline
Old 12-29-2015, 12:52 PM   #4
acadianbob's Avatar
OK, this seems like it is on the edge. I've got 250 lbs in tonneau and side steps. Me, wife, 2 dogs; probably 350. Hitch 250. Other stuff 100. I'm probably below 1,000 lbs remaining. . . . .
Make the trailer weights wet and optioned and I'm probably over payload by 200 to 300 pounds. 10 to 15% overload.
It's amazing how you can eat up that payload.
Old 12-29-2015, 01:06 PM   #5
CWSWine's Avatar
The problem I had when I tried to stubby pencil weights was FR site showed a dry percentage weight of 19.8 but adding only 1180 lbs my pin weight jump for dry 1950 to 2740 and 24.1 percent. I was working with 2475 payload coming to close for my comfort to my gross axle weights.
CWSWine is offline
Old 12-29-2015, 01:27 PM   #6
Yup, not enough payload in your truck for that 5er. Someone else already did the math so I won't repeat.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline
Old 12-29-2015, 03:07 PM   #7
The Big Toe's Avatar
Originally Posted by acadianbob View Post
Tow Truck:
5'er:
GVWR 8,043
Hitch Weight 1,043
UVW 6,556
CCC 1,487
Put your choice of some Supersprings or airbags on it, a Hellwig sway bar and you just won't have a problem. At all.
Not even close to a problem.
You could even do it without the bags/springs and the sway bar,IMHO. But why not do it for your own peace of mind.
ETA: 5th wheel hitches sometimes interfere with bags and/or sway bars. Be advised.
But you're not even close to what that bad boy can do
The Big Toe is offline
Old 12-29-2015, 03:08 PM   #8
If the truck had the HD package, you would have plenty of payload, but with just the Max Tow pkg, you will probably be over. A lot of it will depend whether you want to be that limited.
We towed our 5'er with our F-150 EB Crew Cab and it was wonderful, but we had both MaxTow and HD pkg on ours.
merrykalia is offline
Old 12-29-2015, 03:17 PM   #9
I wouldn't do it.
Glen & Lee
Dawsonville, GA
2013 V-Cross Platinum 325VRL
2017 Ford F350 PSD
GlenZ is offline
Old 12-29-2015, 03:23 PM   #10
What's the HD package add?
Closed Thread
5er, f150
