Old 08-27-2015, 10:05 AM   #11
Originally Posted by IronCobra View Post
I have the bracket jackets, but Equalizer actually states that they may reduce sway control since there is no longer metal on metal contact. The brake pad material would provide a friction surface and actually increase the friction and should also decrease noise.
Iron Cobra,the Old School Friction sway bars that have a bar between two (Brake pads) and activated by turning a threaded arm! The proper way to use these is (Hand Tighten VERY firmly) as per the MFG. These can also be (Very Noisy) also,and people (Loosen) them to reduce the Noise,thus (Not effective Sway Control)! Youroo!!
youroo is online now   Reply With Quote
Old 08-27-2015, 11:58 AM   #12
Rideandslide's Avatar
The Reese SC , beat you to it ! Has friction pads (looks like brake pads ) on the L brackets.
Rideandslide is offline   Reply With Quote
Old 08-27-2015, 12:02 PM   #13
Actually, that was the reason I omitted Reese from the conversation in my original post.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 08-27-2015, 12:29 PM   #14
thebrakeman's Avatar
I know that there are a number of WDHs with sway control out there that use friction L brackets on the trailer A Frame.
Fastway E2
Equalizer 4Point
Reese (though not included in this conversation for soon to be obvious reasons)
Curt
and a few others.
If I attached a small piece of brake material to the L bracket, I wonder if it would assist in sway control as well as reduce noise.
Here is what I found..
https://www.amazon.com/dp/B00CNUGHCU..._g6F3vbZ7VB1B2
I'm hoping something like this would only enhance the friction and sway control.
For anybody feeling it would decrease noise, that's a crap shoot. Ever heard the term "creep groan"? When you creep forward at a stop sign, with your foot still lightly on the brake? Very common noise, it's a stick-slip phenomenon. Actually, that's exactly what you get with the steel-steel interface.
it ain't broken. Don't fix it.
thebrakeman is offline   Reply With Quote
Old 08-27-2015, 05:08 PM   #15
Originally Posted by bikendan View Post
Equal-i-zer has optional "Bracket Jackets" that go in the L-bracket, to help with noise.
Sway Bracket Jacket (pair) : Equal-i-zer Hitch Store
Use the "Bracket Jacket" with good results.
VMI'62
Edmund is offline   Reply With Quote
Old 08-27-2015, 05:17 PM   #16
Citrus County, Fl.
GL1800Rider's Avatar
I used the bracket jackets with no reduction in sway control. As you break in the WDH is seems to quiet down. By the way, I have my 12000/1200 listed in the classifieds. May entertain shipping it, but don't know what the charges would be.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-27-2015, 07:47 PM   #17
I likely would have purchased it from you if the shipping wouldn't have made it more expensive than the one I ordered from Etrailer. I ordered the model without the shank since I have a 12" drop shank already.
Old 08-28-2015, 12:41 AM   #18
Wingdreamer's Avatar
Agreed!
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
hitch, sway
