Old 08-26-2015, 01:13 PM   #1
Those with L Bracket Sway Hitches
I know that there are a number of WDHs with sway control out there that use friction L brackets on the trailer A Frame.
Fastway E2
Equalizer 4Point
Reese (though not included in this conversation for soon to be obvious reasons)
Curt
and a few others.
If I attached a small piece of brake material to the L bracket, I wonder if it would assist in sway control as well as reduce noise.
Here is what I found..
https://www.amazon.com/dp/B00CNUGHCU..._g6F3vbZ7VB1B2
I'm hoping something like this would only enhance the friction and sway control.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 08-26-2015, 01:22 PM   #2
It is an idea but I dont know why a person would need them (maybe I am missing something). It seems if you set up your WDH correctly and it was the proper one (spring weight and what not) then something like this wouldn't be needed. I have a 2012 2500 and a 33 foot (overall) trailer and it has no sway and the friction on the bar seems adequate. Following to see what others have to say.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-26-2015, 01:25 PM   #3
I agree, but it would be interesting and might actually prolong the life of the B Brackets and trunion bars. Also, might be a quieter setup. Wouldn't be hard to JB Weld the brake material to them. just an idea.
Old 08-26-2015, 02:05 PM   #4
Head Rambler
I don't think it would hurt the sway damping ability and may actually inprove it, and it should certainly dampen the noise. It would also reduce the wear on the "L" brackets as well as the spring bars.
Gotta go campin!
Old 08-26-2015, 03:46 PM   #5
bikendan's Avatar
Equal-i-zer has optional "Bracket Jackets" that go in the L-bracket, to help with noise.
http://www.equalizerhitch.com/store/...products_id=66
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-26-2015, 06:22 PM   #6
X 2 on the bracket jackets
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 08-26-2015, 06:35 PM   #7
Who Dares, Wins
doc73's Avatar
Just picked up the brackets and they showed up yesterday. Towing to NJ coming up so I will see how they work...
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 08-27-2015, 09:45 AM   #8
Sway Bracket Jacket (pair) : Equal-i-zer Hitch Store
I have the bracket jackets, but Equalizer actually states that they may reduce sway control since there is no longer metal on metal contact. The brake pad material would provide a friction surface and actually increase the friction and should also decrease noise.
Old 08-27-2015, 09:53 AM   #9
Georgia Frog Rally 2018
aceinspp's Avatar
I for one could care less about the noise. No big deal. It's the end results I'm interested in and that is preventing sway. My Equalizer 4 point WDH does just that and I'm happy. BTW how long do you think it's going to take to where out the brackets? I doubt I'll be around long enough to find out. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 08-27-2015, 10:04 AM   #10
ryand's Avatar
I guess i am missing something with these sway bar jackets and the proposed brake material. I switched from the Husky Centerline (Old Design) to the Equalizer 4 point and too experienced noise. Tuns out it was at the hitch head and not the l brackets. I greased the head as recommendation equalizer and the noise is nearly non existent. The low speed noise is likely coming from the brackets but its nothing other than a few pops. From an engineering stand point a huge portion of anti sway is due to the head and the lateral forces applied to the surfaces of the sockets. If set up correctly and maintained i don't see the need for the jackets or any additional friction forces. You may need to adjust the hitch and go with a tighter toque on the hitch head socket bolts. I check mine before each trip to ensure there is equal tension on both bars. JMO
I will also say not likely but a possibility of increasing the amount of friction to the bar surface could potentially have consequences similar to the reason why with the friction sway bar you must reduce the force when driving in rain or snow. Just a thought.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
hitch, sway
