Old 02-07-2019, 06:59 PM   #1
Thoughts on Auto Level in Rams
Iíve been looking around at trucks and found some of the 18 Ram 3500ís have factory auto level.
Anyone here have any experience with this setup and tow a 5ther?
Robert B is offline   Reply With Quote
Old 02-07-2019, 07:15 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Originally Posted by Robert B View Post
I’ve been looking around at trucks and found some of the 18 Ram 3500’s have factory auto level.
I ordered it on my 2500 Ram and love it. Better ride when towing and also it makes it easier to hook up my tt as I just lower the truck and do not need to raise the tt as much. Think it would work great also with the 5er. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 4
Old 02-08-2019, 10:27 AM   #3
Curious, do the 2500ís have coils or leafs in the rear?
The 3500 has leafs.
Old 02-08-2019, 11:24 AM   #4
Fulltime family RVer
I have it on my 2018 Ram 3500 dually/crew cab/long bed. With my 2012 Ram 3500 dually/crew cab/long bed, I would get people flashing their high beams at me with my old rig (3,000 lbs. of pin weight) and new rig (3,400 lbs. of pin weight). That doesn't happen with the air bags.
I can say that for whatever reason, the new 2018 is a harsher unloaded ride. I don't know if it's the air bags or what. But this new truck really seems to beat us up.
When unhitching, you have to disable the air bag system. If you don't, when you take the pin weight off of the truck bed, the system dumps the air bags which then binds the fifth wheel hitch against the king pin. We found that out the first time unhitching.
We get the camper settled to where we need it to be and then I go into the on-screen menus and enable "Tire Jack Mode". This keeps the air pressure as it was until you move the truck. We unhitch and pull the truck forward which it then dumps out the air.
Hitching up is nice because the inflating helps with the landing gear and gets everything set for the pull test. Once the weight is on the truck/hitch, the system auto inflates the bags. This puts the landing gear just an inch or so off the ground. We kick out the boards, I pull test, and then we finish raising the landing gear and pulling chocks out.
Old 02-08-2019, 11:28 AM   #5
aceinspp's Avatar
The 3500 has leafs.
The 2500 has coil springs. Later RJD
Days camped 2017 62
Days camped 2018 67
Days camped 2019 4
Old 02-08-2019, 11:36 AM   #6
aceinspp's Avatar
I'm guessing your harsher ride is due to the leaf spring set up. My trucks rides very smoothly compared to my Chevy I had and also with the tt in tow it smooths out the ride a lot on the wash boarding on concrete roads.
Little confused as to you saying you have to dump the air. I guess not having all the weight you have your truck does different things compared to mine. When I get ready to unhook I lower the truck then use the power jack to lift tt off ball. Drive out and then raise truck to normal. BTW what new truck still old in signature Later RJD
Days camped 2017 62
Days camped 2018 67
Days camped 2019 4
Old 02-08-2019, 11:53 AM   #7
Thanks for the signature reminder.. it's only been 6 months. Funny, though- it was literally a 1-character change!
I think the new truck and my older 2012 were both leaf springs. I guess with the increase in payload/GVWR (12,300 vs. 14,000), they had to stiffen things up somewhere.
Old 02-08-2019, 12:09 PM   #8
Lins's Avatar
Not with the air suspension, it's bags only in that case.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is offline   Reply With Quote
Old 02-08-2019, 12:17 PM   #9
I have auto level on my 15 Mega Cab dually. I love it, and have not had any issues with it. I do not do anything fancy when unhitching and have never had a problem. I'm guessing I leave more weight on the truck than others? Great feature, it was an overdue option in my opinion.
2015 Trilogy 38RE
-lenny- is offline   Reply With Quote
Old 02-08-2019, 12:24 PM   #10
aceinspp's Avatar
True my bad was looking at different rear on truck. Guess that why it rides good.
Later RJD
Days camped 2017 62
Days camped 2018 67
Days camped 2019 4
